Need help: GLCD shield PCB
Hi all
I'm creating an application with an Arduino and a GLCD module (http://www.nkcelectronics.com/graphic-lcd-module-112864.html). I've got the system working, but I don't like the amount of wires that need to be soldered. A much cleaner solution would be a circuit board where one could connect an Arduino on the other side, and the GLCD on the other side, simply by plugging them both in with pin strip headers.
I tried designing such a PCB with Eagle, but the learning curve for using Eagle proved much too steep, since I've never used it before.
Attached is what I managed to do with Eagle, which isn't much and probably needs some corrections as well(at least the surface mount resistor should be replaced with just holes for a regular one). Anyone willing to help by creating the required Gerber files? I'm sure quite a few people would find this kind of PCB useful.
Attachment: http://ampli.fi/files/shield.zip
