Need Help how to implement funktion
Im new to arduino / coding in general but already made some working codes by spying some other projects in this forum with the same funktions :smiley:
but now I dont have a cloue how to solve following situation:
I have an analog input with an constant on/off frequency ( a turn indicator from a car)
while this Indicator is Blinking, I want an led on an output pin to turn on (not flashing like the input).
if anyone can help me would be very nice :slight_smile:
You need to determine a state change of indicator. Once the indicator goes off after it was on (or vice versa) - remember the system time (millis).
If, say, less than 1 second has passed since the last change, the light is on, more than that, it goes out
You can aldo use a timer.
if (blink==HIGH) {
    reset timer;
if (!timer overdue) {
    put on Led;
The timer should be set for a duration just a bit longer than your blinking interval.
  static unsigned long TimeLastHigh = 0;
  // Turn on the LED when the blinker goes on.
  if (digitalRead(InputPin) == HIGH)
    digitalWrite(OutputPin, HIGH); // Turn on LED
    TimeLastHigh = millis();
  // Turn off the LED when the blinker has been off for 1 second.
  if (millis() - TimeLastHigh >= 1000)
    digitalWrite(OutputPin, LOW); // Turn LED off
