Need help: How to send Visual Studio output to WiFi Shield?
I am a 10th Grader doing basic level programming in C++. Got interested in Arduino couple months back and my first project was sending Kinect data to UNO controlling speed of a small fan (that I was able to do using USB Serial).
I am now trying to do the same over WiFi but having issues. Below is my code that I got from forums and it works to the point where CC3000 WiFi Shield is able to connect to router but I am not able to send (Visual Studio) program output to WiFi Shield. Will really appreciate if someone could help me with either code or technical design how do I send my visual studio program output to WiFi Shield.
Thank You!
Arduino Code (Adafruit example library "EchoServer"):
  Adafruit CC3000 Breakout/Shield TCP Echo Server
  Written by Limor Fried & Kevin Townsend for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include "utility/debug.h"
#include "utility/socket.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID       "dlink"           // cannot be longer than 32 characters!
#define WLAN_PASS       "myPassword"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
#define LISTEN_PORT           7    // What TCP port to listen on for connections.  The echo protocol uses port 7.
Adafruit_CC3000_Server echoServer(LISTEN_PORT);
void setup(void)
  Serial.println(F("Hello, CC3000!\n"));
  Serial.print("Free RAM: "); Serial.println(getFreeRam(), DEC);
  /* Initialise the module */
  Serial.println(F("\nInitializing..."));
  if (!cc3000.begin())
    Serial.println(F("Couldn't begin()! Check your wiring?"));
    while(1);
  Serial.print(F("\nAttempting to connect to ")); Serial.println(WLAN_SSID);
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    Serial.println(F("Failed!"));
    while(1);
  Serial.println(F("Connected!"));
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (! displayConnectionDetails()) {
  /* You can safely remove this to save some flash memory! */
  Serial.println(F("\r\nNOTE: This sketch may cause problems with other sketches"));
  Serial.println(F("since the .disconnect() function is never called, so the"));
  Serial.println(F("AP may refuse connection requests from the CC3000 until a"));
  Serial.println(F("timeout period passes.  This is normal behaviour since"));
  Serial.println(F("there isn't an obvious moment to disconnect with a server.\r\n"));
  // Start listening for connections
  echoServer.begin();
  Serial.println(F("Listening for connections..."));
void loop(void)
  // Try to get a client which is connected.
  Adafruit_CC3000_ClientRef client = echoServer.available();
  if (client) {
     // Check if there is data available to read.
     if (client.available() > 0) {
       // Read a byte and write it to all clients.
       uint8_t ch = client.read();
       client.write(ch);
    @brief  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
    return true;
Visual Studio Code (C++):
#define WIN32_LEAN_AND_MEAN
#include <windows.h>
#include <WinSock2.h>
#include <ws2tcpip.h>
#include <stdlib.h>
#include <stdio.h>
#include<iostream>
// Need to link with Ws2_32.lib, Mswsock.lib, and Advapi32.lib
#pragma comment (lib, "Ws2_32.lib")
#pragma comment (lib, "Mswsock.lib")
#pragma comment (lib, "AdvApi32.lib")
#define DEFAULT_BUFLEN 512			//Default buffer length of port
#define DEFAULT_PORT "7"		//Change this to change port
int main()//int argc, char **argv
	WSADATA wsaData;
	SOCKET ConnectSocket = INVALID_SOCKET;
	struct addrinfo *result = NULL,
		*ptr = NULL,
		hints;
	char *sendbuf = "100";
	char recvbuf[DEFAULT_BUFLEN];
	int iResult;
	int recvbuflen = DEFAULT_BUFLEN;
	// Validate the parameters - not necessary for use
	if (argc != 2) {
		printf("usage: %s server-name\n", argv[0]);
		system("pause"); return 1;
	// Initialize Winsock
	iResult = WSAStartup(MAKEWORD(2, 2), &wsaData);
	if (iResult != 0) {
		printf("WSAStartup failed with error: %d\n", iResult);
	ZeroMemory(&hints, sizeof(hints));
	hints.ai_family = AF_UNSPEC;
	hints.ai_socktype = SOCK_STREAM;
	hints.ai_protocol = IPPROTO_TCP;
	// Resolve the server address and port
	iResult = getaddrinfo(NULL, DEFAULT_PORT, &hints, &result);
	if (iResult != 0) {
		printf("getaddrinfo failed with error: %d\n", iResult);
		WSACleanup();
	// Attempt to connect to an address until one succeeds
	for (ptr = result; ptr != NULL; ptr = ptr->ai_next) {
		// Create a SOCKET for connecting to server
		ConnectSocket = socket(ptr->ai_family, ptr->ai_socktype,
			ptr->ai_protocol);
		if (ConnectSocket == INVALID_SOCKET) {
			printf("socket failed with error: %ld\n", WSAGetLastError());
			WSACleanup();
		// Connect to server.
		iResult = connect(ConnectSocket, ptr->ai_addr, (int)ptr->ai_addrlen);
		if (iResult == SOCKET_ERROR)
			closesocket(ConnectSocket);
			continue;
	freeaddrinfo(result);
	if (ConnectSocket == INVALID_SOCKET) //If failed to get a socket, end program
		printf("Unable to connect to server!\n");
		WSACleanup();
	// Send an initial buffer
	iResult = send(ConnectSocket, sendbuf, (int)strlen(sendbuf), 0);
	if (iResult == SOCKET_ERROR) {
		printf("send failed with error: %d\n", WSAGetLastError());
		WSACleanup();
	printf("Bytes Sent: %ld\n", iResult);
	// Receive until the peer closes the connection
	do {
		iResult = recv(ConnectSocket, recvbuf, recvbuflen, 0);
		if (iResult > 0)
			printf("Bytes received: %d\n", iResult);
			std::cout << recvbuf << std::endl;
		else if (iResult == 0)
			printf("Connection closed\n");
			printf("recv failed with error: %d\n", WSAGetLastError());
	} while (iResult > 0);
	// shutdown the connection since no more data will be sent
	iResult = shutdown(ConnectSocket, SD_SEND);
		printf("shutdown failed with error: %d\n", WSAGetLastError());
		WSACleanup();
	// cleanup
	WSACleanup();
	return 0;
