Need Help , I cant find the problem with it . :(
#include <LiquidCrystal.h> // includes the LiquidCrystal Library
#include <Keypad.h>
#define buzzer 11
#define trigPin 12
#define echoPin 10
long duration;
int distance, initialDistance, currentDistance, i;
int screenOffMsg =0;
String password="1234";
String tempPassword;
boolean activated = false; // State of the alarm
boolean isActivated;
boolean activateAlarm = false;
boolean alarmActivated = false;
boolean enteredPassword; // State of the entered password to stop the alarm
boolean passChangeMode = false;
boolean passChanged = false;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keypressed;
//define the cymbols on the buttons of the keypads
char keyMap[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {7, 6, 5, 4}; //Row pinouts of the keypad
byte colPins[COLS] = {3, 2, 1, 0}; //Column pinouts of the keypad
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, ROWS , COLS);
const int rs = 13, en = 12, d4 = 11, d5 = 10, d6 = 9, d7 = 8;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
lcd.begin(16,2);
pinMode(buzzer, OUTPUT); // Set buzzer as an output
pinMode(trigPin,OUTPUT); // Set trigPin as an Input
pinMode(echoPin,INPUT); // Sets the echoPin as an Input
if (activateAlarm) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Alarm will be");
lcd.setCursor(0,1);
lcd.print("activated in");
int countdown = 5; // 5 seconds count down before activating the alarm
while (countdown != 0) {
lcd.setCursor(13,1);
lcd.print(countdown);
countdown--;
tone(buzzer, 700, 100);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Alarm Activated!");
lcd.setCursor(0,1);
lcd.print("By wajdi&meryem");
initialDistance = getDistance();
alarmActivated = true;
if (alarmActivated == true){
currentDistance = getDistance() + 10;
if ( currentDistance < initialDistance) {
tone(buzzer, 1000); // Send 1KHz sound signal
lcd.clear();
enterPassword();
if (!alarmActivated) {
if (screenOffMsg == 0 ){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("A- Activate");
lcd.setCursor(0,1);
lcd.print("B- Change Pass");
screenOffMsg = 1;
keypressed = myKeypad.getKey();
if (keypressed =='A'){ //If A is pressed, activate the alarm
tone(buzzer, 1000, 200);
activateAlarm = true;
else if (keypressed =='B') {
lcd.clear();
int i=1;
tone(buzzer, 2000, 100);
tempPassword = "";
lcd.setCursor(0,0);
lcd.print("Current Password");
lcd.setCursor(0,1);
lcd.print(">");
passChangeMode = true;
passChanged = true;
while(passChanged) {
if (keypressed != NO_KEY){
if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' ||
keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' ||
keypressed == '8' || keypressed == '9' ) {
tempPassword += keypressed;
lcd.setCursor(i,1);
lcd.print("");
i++;
if (i > 5 || keypressed == '#') {
tempPassword = "";
i=1;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(">");
if ( keypressed == '
i=1;
if (password == tempPassword) {
tempPassword="";
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set New Password");
lcd.setCursor(0,1);
lcd.print(">");
while(passChangeMode) {
lcd.setCursor(i,1);
lcd.print("");
i++;
tempPassword = "";
i=1;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(">");
i=1;
password = tempPassword;
screenOffMsg = 0;
void enterPassword() {
int k=5;
tempPassword = "";
activated = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" * ALARM * ");
lcd.setCursor(0,1);
lcd.print("Pass>");
while(activated) {
lcd.setCursor(k,1);
lcd.print("");
k++;
if (k > 9 || keypressed == '#') {
tempPassword = "";
k=5;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Pass>");
if ( tempPassword == password ) {
activated = false;
noTone(buzzer);
screenOffMsg = 0;
else if (tempPassword != password) {
lcd.setCursor(0,1);
lcd.print("Wrong! Try Again");
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Pass>");
// Custom function for the Ultrasonic sensor
long getDistance(){
//int i=10;
//while( i<=10 ) {
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance = duration*0.034/2;
//sumDistance += distance;
//int averageDistance= sumDistance/10;
return distance;
The biggest problem with IT is that it is not posted correctly see:- How to use this forum - please read. - Installation & Troubleshooting - Arduino Forum
The second problem you have is that you have not described what sort of problem you have:-
  1. Dosn't compile
  2. Dosn't run
  3. Runs but dosn't to the right thing.
Finally WTF is it supposed to do, or are we supposed to guess from looking at the code?
First issue is loop() is way too long - break it down into smaller functions, name them according to function.
You seem to have a task best suited as a finite state machine driven by key presses? Structure the code
to match the states / modes, arrange to handle unexpected keypad input in a uniform way.
And use lots more blank lines - text without paragraph breaks is hard to read, code without frequent
breaks is also hard to read (but splitting into separate functions is the first thing to fix). It'll be much
easier to navigate the code and make incremental changes/improvements.
Then you can look for you actual problem without confusion!
