Need help! i dont know how to deal with it
No matter what i write (even i wanna to print hello),the problem will arise,while compiling.
it not work ,i have uninstalled the arduino IDE or Platformio ,install them again and again.
the error
Arduino:1.8.13 (Windows 10), 开发板:"Arduino Uno"
D:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Arduino\hardware -hardware C:\Users\多喝热水\AppData\Local\Arduino15\packages -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -tools C:\Users\多喝热水\AppData\Local\Arduino15\packages -built-in-libraries D:\Arduino\libraries -libraries C:\Users\多喝热水\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10813 -build-path C:\Windows\TEMP\arduino_build_682238 -warnings=none -build-cache C:\Windows\TEMP\arduino_cache_853974 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=D:\Arduino\hardware\tools\avr -verbose C:\Windows\TEMP\untitled1179121659.tmp\sketch_apr20a\sketch_apr20a.ino
D:\Arduino\arduino-builder -compile -logger=machine -hardware D:\Arduino\hardware -hardware C:\Users\多喝热水\AppData\Local\Arduino15\packages -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -tools C:\Users\多喝热水\AppData\Local\Arduino15\packages -built-in-libraries D:\Arduino\libraries -libraries C:\Users\多喝热水\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10813 -build-path C:\Windows\TEMP\arduino_build_682238 -warnings=none -build-cache C:\Windows\TEMP\arduino_cache_853974 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=D:\Arduino\hardware\tools\avr -verbose C:\Windows\TEMP\untitled1179121659.tmp\sketch_apr20a\sketch_apr20a.ino
Using board 'uno' from platform in folder: D:\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: D:\Arduino\hardware\arduino\avr
Detecting libraries used...
"D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Windows\TEMP\arduino_build_682238\sketch\sketch_apr20a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Windows\TEMP\arduino_build_682238\sketch\sketch_apr20a.ino.cpp" -o "C:\Windows\TEMP\arduino_build_682238\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"D:\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Windows\TEMP\arduino_build_682238\preproc\ctags_target_for_gcc_minus_e.cpp"
正在编译项目...
"D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Windows\TEMP\arduino_build_682238\sketch\sketch_apr20a.ino.cpp" -o "C:\Windows\TEMP\arduino_build_682238\sketch\sketch_apr20a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Windows\TEMP\arduino_cache_853974\core\core_arduino_avr_uno_fd040c28ca717db04400ddff4ecd4334.a
Linking everything together...
"D:\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Windows\TEMP\arduino_build_682238/sketch_apr20a.ino.elf" "C:\Windows\TEMP\arduino_build_682238\sketch\sketch_apr20a.ino.cpp.o" "C:\Windows\TEMP\arduino_build_682238/..\arduino_cache_853974\core\core_arduino_avr_uno_fd040c28ca717db04400ddff4ecd4334.a" "-LC:\Windows\TEMP\arduino_build_682238" -lm
avr-gcc: error: @C:\Windows\TEMP\ccqHQQFz: Invalid argument
avr-gcc: fatal error: no input files
compilation terminated.
lto-wrapper.exe: fatal error: D:\Arduino\hardware\tools\avr/bin/avr-gcc returned 1 exit status
d:/arduino/hardware/tools/avr/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
Post:
  • code
  • circuit (drawing or photo)
  • explain what you are trying to do
I have not write any code . I mean no matter what i write (even i wanna to print hello),the problem will arise,while compiling. i have no idea to fix it
Please don't post images of code and error message.
For the error message, the button below probably means 'copy error message'; click it and paste the result in a post.
For code, use
your code here
So it looks like
your code here
sorry , i see . Actually no matter whether there is code or not ,this question will appear . ( even i have not write any code. )Maybe its not my code 's fault.
I know that you haven't written code yet. But we would like to see the full error message.
i know what you meaning now, and i will pay attention to it later.
The only thing that looks strange to me is the quotes around the second-to-last argument to the linker:
“-LC:\Windows\TEMP\arduino_build_682238”
On my Macintosh there are no quotes around any of the file paths so I don't know if that is normal or not.
Start by checking for an update. Select Tools->Board->Boards Manager... Then, in the 'Type' menu, select "Updatable". That will show you the list of boards for which there is an available update. maybe "Arduino AVR Boards" needs an update.
If that doesn't fix the problem, re-install the Arduino IDE.
THANKS , I've solved this problem ,I’ve modified the environment variables of the computer in order to use another software.
i found the answer form this line ,
"C:\Windows\TEMP\ccqHQQFz: Invalid argument"
THEN, i modified it .Everything gose well
