Need help in coding for the color sensor TCS3200
I found this code on the net. I am not really getting the exact color prediction. Is their something wrong with the code?? Is their any other code for TCS3200??
const int s0 = 8;
const int s1 = 9;
const int s2 = 12;
const int s3 = 11;
const int out = 10;
// LED pins connected to Arduino
int redLed = 2;
int greenLed = 3;
int blueLed = 4;
// Variables
int red = 0;
int green = 0;
int blue = 0;
  pinMode(s0, OUTPUT);
  pinMode(s1, OUTPUT);
  pinMode(s2, OUTPUT);
  pinMode(s3, OUTPUT);
  pinMode(out, INPUT);
  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  pinMode(blueLed, OUTPUT);
  digitalWrite(s0, HIGH);
  digitalWrite(s1, HIGH);
   pinMode(13, OUTPUT);
 digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  color();
  Serial.print("R Intensity:");
  Serial.print(red, DEC);
  Serial.print(" G Intensity: ");
  Serial.print(green, DEC);
  Serial.print(" B Intensity : ");
  Serial.print(blue, DEC);
  //Serial.println();
  if (red < blue && red < green && red < 10)
   Serial.println(" - (Red Color)");
   digitalWrite(redLed, HIGH); // Turn RED LED ON
   digitalWrite(greenLed, LOW);
   digitalWrite(blueLed, LOW);
  else if (blue < red && blue < green)
   Serial.println(" - (Blue Color)");
   digitalWrite(redLed, LOW);
   digitalWrite(blueLed, HIGH); // Turn BLUE LED ON
  else if (green > red && green > blue)
   Serial.println(" - (Green Color)");
   digitalWrite(greenLed, HIGH); // Turn GREEN LED ON
  else{
  delay(300);
void color()
  digitalWrite(s2, LOW);
  digitalWrite(s3, LOW);
  //count OUT, pRed, RED
  red = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
  digitalWrite(s3, HIGH);
  //count OUT, pBLUE, BLUE
  blue = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
  digitalWrite(s2, HIGH);
  //count OUT, pGreen, GREEN
  green = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
Thank you.
Which is what?
The code does exactly what it is does.
Sure if you want to write it.
