Need help in designing a Smart led bulb with Smoke detection
Hello,
I am thinking of designing a smart led bulb with smoke/fire detection in it.
The problem I am facing is that I am not able to constantly keep the smoke detection in ON state, and I also want the whole circuit to reset once the buzzer goes OFF.
The circuit image is attached.
I want help in integrating an RGB bulb and a smoke sensor together.
This is my code it's very cluttery because I had to use workarounds in order to get that smoke sensor working at all times.
int red_light_pin = 11;
int green_light_pin = 9;
int blue_light_pin = 8;
int smoke_input = A5;
int smoke_level = 0;
int smoke_thres = 450;
int buzz = 10;
  pinMode(red_light_pin, OUTPUT);
  pinMode(green_light_pin, OUTPUT);
  pinMode(blue_light_pin, OUTPUT);
  pinMode(buzz, OUTPUT);
void RGB_color(int red_light_value, int green_light_value, int blue_light_value)
  analogWrite(red_light_pin, red_light_value);
  analogWrite(green_light_pin, green_light_value);
  analogWrite(blue_light_pin, blue_light_value);
void smoke_read() {
  Serial.println(analogRead(smoke_input));
  smoke_level = analogRead(smoke_input);
  delay(10);
void fire_alarm()
  if (smoke_level > smoke_thres) {
    RGB_color(255, 0, 0);
    digitalWrite(buzz, HIGH);
    delay(6000);
    rgb_effect1();
    digitalWrite(buzz, LOW);
void rgb_effect1() {
  smoke_read();
  RGB_color(0, 0, 255);
  fire();
  RGB_color(255, 255, 125);
  fire();
  RGB_color(0, 255, 255);
  fire();
  RGB_color(255, 0, 255);
  fire();
  RGB_color(255, 255, 0);
  fire();
  RGB_color(255, 255, 255);
  fire();
void fire(){
  smoke_read();
  fire_alarm();
  smoke_read();
  fire_alarm();
  rgb_effect1();
Thanks for reading if you did. I really appreciate the help.
Now the smoke detector must by definition, contain a battery (nowadays, lithium with a ten year lifetime, and its own buzzer), otherwise it would be simply unsuitable.
The smoke detector must have a switch output to trip the Arduino. The only ones that I know of which have such an output are those designed to be wired to the mains. What one are you proposing to use?
