NEED HELP in establishing Wireless Communication between two arduino .
As you can see from the code below, i am trying to make one of my arduino to become the server and the other one to be the client.
I need a system which can share and send information between two arduinos.
The problem i faced now, is i wont be able to connect my client to the server.
Is there anyone can guide me on this?
Client Code:
(Start by adding Code tags. Moderator)
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "9 Harcourt 2.4"; //  your network SSID (name)
char pass[] = "11111";
int status = WL_IDLE_STATUS;
byte server[] = { 192,168,0,10 };
WiFiClient client;
  Serial.println("Attempting to connect to WPA network...");
  Serial.print("SSID: ");
  Serial.println(ssid);
  status = WiFi.begin(ssid, pass);
  if ( status != WL_CONNECTED) {
    Serial.println("Couldn't get a wifi connection");
    // don't do anything else:
    while(true);
  else {
    Serial.println("Connected to wifi");
    printWifiStatus();
    Serial.println("\nStarting connection...");
    // if you get a connection, report back via serial:
    if (client.connect(server, 80)) {
      Serial.println("connected");
      // Make a HTTP request:
      client.println("GET /search?q=arduino HTTP/1.0");
      client.println();
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Server Code:
#include <SPI.h>
#include <WiFi.h>
int keyIndex = 0;            // your network key Index number (needed only for WEP)
WiFiServer server(80);
boolean alreadyConnected = false; // whether or not the client was connected previously
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    // wait 10 seconds for connection:
    delay(10000);
  // start the server:
  server.begin();
  // you're connected now, so print out the status:
  printWifiStatus();
  // wait for a new client:
  WiFiClient client = server.available();
  // when the client sends the first byte, say hello:
  if (client) {
    if (!alreadyConnected) {
      // clead out the input buffer:
      client.flush();
      Serial.println("We have a new client");
      client.println("Hello, client!");
      alreadyConnected = true;
    if (client.available() > 0) {
      // read the bytes incoming from the client:
      char thisChar = client.read();
      // echo the bytes back to the client:
      server.write(thisChar);
      // echo the bytes to the server as well:
      Serial.write(thisChar);
  Serial.println(ip);
  Serial.print(rssi);
server.ino (2.21 KB)
client.ino (1.34 KB)
