Hello guys. I would appreciate some help in optimizing my code. I developed an SMS-based LED Matrix Display using Arduino. Here's a link to the thread.
http://arduino.cc/forum/index.php/topic,126897.0.html
and here's the video: SMS-Based LED Matrix Display using Gizduino (version 2) - YouTube
I used a 8x32 LED Matrix Display back then. But now I'm developing the same project, only this time, i'm using a 8x64 LED Matrix Display.
I edited the code to apply the two Matrices, but I encountered problems when it displays the text messages. It shows text message 1 then displays random characters. I'm guessing this is a memory problem. any help? here's the new code:
#include "cmap.h" // character map libarary
#include <SIM900.h> // SIM900D library
#include <sms.h> // SMS libarart
#include <SoftwareSerial.h> // Software Serial Library
SMSGSM sms;
#define INTEN 6500 //scroll speed.
//the higher the value, the slower the scroll
//-----------------LED MATRIX PINS------------------
#define CLK 5 // clock pin connected to digital pin 5
#define DAT 6 // Data pin connected to digital pin 6
#define STR 7 // Strobe pin connected to digital pin 7
#define K0 A0 // Data 0 connected to analog pin 0
#define K1 A1 // Data 1 connected to analog pin 1
#define K2 A2 // Data 2 connected to analog pin 2
#define K3 A3 // Data 3 connected to analog pin 3
#define K4 8 // Data 4 connected to digital pin 8
#define K5 9 // Data 5 connected to digital pin 9
#define K6 10 // Data 6 connected to digital pin 10
#define K7 11 // Data 7 connected to digital pin 11
//-------------------GSM VARIABLES-----------------------
boolean MSG_RCVD = false; // no message recieved as initial value
const char regnum[] = "639177915470"; // admin number
const char passRx[] = "default#"; // holds password, must be 8 char only! and ends with #
char smsdata[160]; // sms only accept 160 characters
char numberRx[20]; // holds sender number
char *inbox[5]; // holds text messages
int message_no; // message counter
int loop_count = 1; // loop count of messages
int inbox_no = -1; // inbox no index (starts at 0)
unsigned int d; // for INTEN and strobe
//-----------------LED MATRIX VARIABLES------------------
char Display_Ram[76]; // locates the the ASCII Character Map Display
char count; // counter for
unsigned char char_pointer = 0x00; // character pointer for smsdata and LED_DATA arrays
unsigned char mask; // for masking the display
unsigned char shift_counter; // for scrolling the message
int pins[] = { CLK, DAT, STR, K0, // pins for LED Matrix
K1, K2, K3, K4, K5,
K6, K7 };
int mask_data[] = {0x80, 0x40, 0x20, // mask for LED Matrix Display
0x10, 0x08, 0x04,
0x02, 0x01};
// unsigned int matrix_size = 64;
// ---------- serial setup ----------
gsm.begin(4800); // initialize GSM
pinsetup(); // setup the pins for LED
Display(); // call display
shift(); // shift from right to left
void pinsetup() // setup pins for display
for (int x =0; x<=10; x++){ // all pins OUTPUT
pinMode(pins[x], OUTPUT);
for (int y=3; y <=10; y++){ // K0-K7 HIGH
digitalWrite(pins[y],HIGH);
for(d=0;d<64;d++){
clock();
strobe();
d = 0;
void checkSMS ()
// ---------- check if there is new message ----------
int i;
if(gsm.readSMS(smsdata, 160, numberRx, 20))
// read new message and store in smsdata and numberRx
if (strncmp (numberRx, regnum, 11) == 0 && strncmp (smsdata, passRx, 8) == 0)
// check if sender number and password is correct, then continue
while (smsdata[i] != '\0')
smsdata[i] = smsdata[i+8]; // delete the password from the string
i++;
sms.SendSMS("09177915470", "Message was Recieved");
MSG_RCVD = true; // confirm that new message is recieved
loop_count++; // increment loop count
store(); // store new message in inbox array
void store()
inbox_no++; // increment from -1
if (inbox_no >= 5) // check if inbox is full
inbox_no = 0; // reset inbox_no
inbox[0]; // clear inbox from 0-4
inbox[1];
inbox[2];
inbox[3];
inbox[4];
inbox[inbox_no] = strdup(smsdata); // dump string into inbox number
void Display (void) // display the data to the LED Matrix
int i = 0;
for (i = 7; i >=0 ; i--)
mask = mask_data[i] ;
scan();
digitalWrite(pins[i],LOW); // pin ON
for(d=0;d<INTEN;d++){}
digitalWrite(pins[i],HIGH); // pin OFF
void scan(void)
for (count = matrix_size;count>(-1);count--){
if ((Display_Ram[count] & mask) == mask)
digitalWrite(DAT,LOW); // data pin OFF
digitalWrite(DAT,HIGH); // data pin ON
clock();
strobe();
void clock(void){
digitalWrite(CLK,HIGH); // clock hi
digitalWrite(CLK,LOW); // clock low
void strobe(void){
digitalWrite(STR,HIGH); // strobe hi
digitalWrite(STR,LOW); // strobe low
void shift(void) // Scroll display
for (int val=0; val<74; val++)
Display_Ram[val] = Display_Ram[val+1];
shift_counter++;
if(shift_counter == 6)
shift_counter = 0;
load_data(); // call load_data
void load_data(void)
int counter1 = 0;
char *LED_DATA = announcement(message_no); // dump message to LED_DATA
if(LED_DATA[char_pointer+1] == '\0') // If end of message
char_pointer = 0; // reset character pointer
message_no++; // go to next message
for(counter1 = 0; counter1 < 5; counter1++)
Display_Ram[matrix_size + counter1] = pgm_read_byte(&(character_data[(LED_DATA[char_pointer] - 0x20)][counter1]));
// locate the appropriate character at the CMAP.H
Display_Ram[matrix_size + 10] = 00;
char_pointer++;
if (message_no > loop_count) // only check new messages when the message)no > loop_count
checkSMS(); // check for new message
if (MSG_RCVD == false) // if there are no new messages, continue loop
message_no = 0; // continue loop from the start
MSG_RCVD = false; // then declare no new messages
else if (message_no >= 7) // if messages is 7 or above
message_no = 0; // go back to first message
checkSMS(); // then check for new messages
char *announcement(int message_no2) // where the strings and text messages are stored
char *LED_message[]={" LCoES Announcements ",
" Hello Letranites! ",
inbox[0] ,
inbox[1] ,
inbox[2] ,
inbox[3] ,
inbox[4] };
// FIXED MESSAGE 1 = LCOES ANNOUNCEMENTS
// FIXED MESSAGE 2 = HELLO LETRANITES
// INBOX 0 - 4 = TEXT MESSAGES
return LED_message[message_no2]; // returns message index based from message no.
would really appreciate some help with PROGMEM. thanks!
