Im very new at this arduino world, i have knowledge in PICS and Pic basic Pro im starting sow please give me a hand.
What i want to do is ex: on arduino ide serial terminal send “1234;5678” and de arduino see if the 1st four numbers (or somw letters) are 1234 in this case and then read the next four after the “;”
My code have a problem if a put the god “pass” “1234;tefi” it woks god but when i put a rwong pass like example “e3r5;tec8” and after put the god one “1234;ehf6” it stops working !!
Please see my sample code and help me.
Thankz
char pass [5];
int data;
//Create Serial Object
Serial.println("ARDUINO ON!");
if (Serial.available() >8) { //assumir que o outro byte vem a caminho.
for (int i = 0; i<4; i ++) {
pass[i] = Serial.read();
pass[4] = '\0'; //end string
if ((strcmp(pass, "1234") == 0) && (Serial.read() == ';')) {//equal and the separator is good
for (int i = 0; i< 4; i++) {
pass[i] = Serial.read(); } //get the number.
data = atoi(pass);
Serial.println("PASS OK!");
Serial.println(data);
Serial.println("FAIL");
The problem is that you do not clear the rest of the "wrong" command.
You should introduce a command-end character, such as newline ('\n'), and read characters until that character is seen after the parsing code.
if (Serial.available() > 8) {
do all your stuff
/* now, read all incoming data until end-of-command, so you know the next character will be the start of a new command */
while (true) {
if (Serial.available() > 0 && Serial.read() == '\n') {
First thanks for the help, your code works god except for this situaction if a send the god or wrong pass with out the command-end character “1234;5678” the god one and “2233;5678” the bad next time that i send them with command-end character “1234;5678t”(i have change the command-end character for “t” leter)dont work i need to send a secund time the “1234;5678t” to get "PASS OK! from arduino! any ideas how to solve it?
Thanks
char pass [5];
int data;
data = atoi(pass);
} else
while (true) {
if (Serial.available() > 0 && Serial.read() == 't') {
What are you using to send the data? If you are using the serial monitor, set the option to append a carriage return/line feed, and expect that as the end-of-packet marker. That way, you can't forget to send it.
1234;5678t
is not 8 characters. It is 10!
Now im using the the serial monitor but later i will use other devices...
If i change "if (Serial.available() >8)" to if (Serial.available() >10) the first time that i send the pass dont work need to send it one time more
You are saying that you first send a command without end character, and then send the command again, and then it doesn't work?
That's expected. The code will believe that everything up to the first end character is part of the first command. It can't magically "know" what you "intend" -- the command end character is the only way it can know, so you have to send that.
Another way of implementing your code would be to read data into a buffer, and then parse the command once you have the end character.
That's fine, except that the name bufPtr is horrible. It is an index, not a pointer. It does not point to buffer. bufInd would be a better name, in my opinion.
PaulS:
If we're going for descriptive names, "bufCnt" or "bufEnd" would be even better :-)
