system
November 4, 2013, 10:47am
1
Hi , I am using following sketch and need help in , after using this 2 relays are getting auto on after reseting arduino uno or at starting the uno please tell how to keep relays off during reset or starting the arduino uno rest working fine.
* arduWebRelays.ino
* Created: 07/09/2013 15:55:00
* Author: Guillaume Carriere - guillaume.carriere@gmail.com
#include <EtherCard.h>
static byte mymac[] = { 0x00,0x01,0x01,0x01,0x01,0x01 };
static byte myip[] = { 192,168,0,201 };
#define BUFFER_SIZE 500
byte Ethernet::buffer[BUFFER_SIZE];
BufferFiller bfill;
#define CS_PIN 8
#define RELAIS_1 2
#define RELAIS_2 4
bool relais1Status = false;
bool relais2Status = false;
const char http_OK[] PROGMEM =
"HTTP/1.0 200 OK\r\n"
"Content-Type: text/html\r\n"
"Pragma: no-cache\r\n\r\n";
const char http_Found[] PROGMEM =
"HTTP/1.0 302 Found\r\n"
"Location: /\r\n\r\n";
const char http_Unauthorized[] PROGMEM =
"HTTP/1.0 401 Unauthorized\r\n"
"Content-Type: text/html\r\n\r\n"
"<h1>401 Unauthorized</h1>";
void homePage()
bfill.emit_p(PSTR("$F"
"<title>Arduino Relais Webserver</title>"
"Relais 1: <a href=\"?relais1=$F\">$F</a>
"Relais 2: <a href=\"?relais2=$F\">$F</a>"),
http_OK,
relais1Status?PSTR("off"):PSTR("on"),
relais1Status?PSTR("<font color=\"green\"><b>ON</b></font>"):PSTR("<font color=\"red\">OFF</font>"),
relais2Status?PSTR("off"):PSTR("on"),
relais2Status?PSTR("<font color=\"green\"><b>ON</b></font>"):PSTR("<font color=\"red\">OFF</font>"));
pinMode(RELAIS_1, OUTPUT);
pinMode(RELAIS_2, OUTPUT);
if (ether.begin(BUFFER_SIZE, mymac, CS_PIN) == 0)
Serial.println("Cannot initialise ethernet.");
Serial.println("Ethernet initialised.");
ether.staticSetup(myip);
Serial.println("Setting up DHCP");
if (!ether.dhcpSetup())
Serial.println( "DHCP failed");
ether.printIp("My IP: ", ether.myip);
ether.printIp("Netmask: ", ether.mymask);
ether.printIp("GW IP: ", ether.gwip);
ether.printIp("DNS IP: ", ether.dnsip);
digitalWrite(RELAIS_1, relais1Status);
digitalWrite(RELAIS_2, relais2Status);
delay(1); // necessary for my system
word len = ether.packetReceive(); // check for ethernet packet
word pos = ether.packetLoop(len); // check for tcp packet
if (pos) {
bfill = ether.tcpOffset();
char *data = (char *) Ethernet::buffer + pos;
if (strncmp("GET /", data, 5) != 0) {
// Unsupported HTTP request
// 304 or 501 response would be more appropriate
bfill.emit_p(http_Unauthorized);
else {
Serial.print("----");
Serial.print(data);
Serial.println("----");
data += 5;
if (data[0] == ' ') {
// Return home page
homePage();
else if (strncmp("?relais1=on ", data, 12) == 0) {
relais1Status = true;
bfill.emit_p(http_Found);
else if (strncmp("?relais2=on ", data, 12) == 0) {
relais2Status = true;
else if (strncmp("?relais1=off ", data, 13) == 0) {
else if (strncmp("?relais2=off ", data, 13) == 0) {
else {
// Page not found
ether.httpServerReply(bfill.position()); // send http response
system
November 4, 2013, 10:49am
2
This sets the mode of the pins, not the state. You need to set the state, too.
system
November 4, 2013, 10:51am
3
yes you are right i have tried that but no success . pls help
system
November 4, 2013, 10:55am
4
Then, maybe false is not the correct state that you want to start with.
system
November 4, 2013, 10:56am
5
You could try pull-downs on the relay outputs.
(I can't see your schematic)
system
November 4, 2013, 11:03am
6
AWOL:
I am using a 2 relay module
system
November 4, 2013, 11:06am
7
PaulS:
if i use true in place of false relays are first get on and after some time goes off.
system
November 5, 2013, 6:45am
8
someone help regarding this
Post your amended code please.
system
November 5, 2013, 6:48am
10
Thank you sir ,
* arduWebRelays.ino
BufferFiller bfill;
#define CS_PIN 8
#define RELAIS_1 2
#define RELAIS_2 4
void homePage()
http_OK,
if (pos) {
else {
Serial.print(data);
data += 5;
// Return home page
homePage();
else {
// Page not found
system
November 5, 2013, 7:57am
11
You set the pinMode of the relay outputs, but don't write to them.
Is this intentional?
Hi try
digitalWrite(RELAIS_1,HIGH); // I use HIGH because i thing this relay board's it is reverse the signal, if not works with this way //try LOW
digitalWrite(RELAIS_2,HIGH);
system
November 5, 2013, 11:49am
13
Hi "tasosstr" your changes to code does not changed anything, please look into attached image when it takes a IP address from my router it turn ON relays automatic. and one more thing my Relay board is active-low Thanks for helping me ..
system
November 5, 2013, 11:52am
14
AWOL:
Hello , I have tried what you say but no success .. please help me.
system
November 5, 2013, 11:59am
15
PaulS:
If i changed that state to "TRUE" then the relays are not get auto ON but also not getting on from web page..
system
November 5, 2013, 12:08pm
16
Thank you all of specially "PaulS" , "AWOL", and "tasosstr " Finally its working as expected Thanks again.
here is the code that worked perfect.
* arduWebRelays.ino
BufferFiller bfill;
#define CS_PIN 8
#define RELAIS_1 2
#define RELAIS_2 4
bool relais1Status = true;
bool relais2Status = true;
void homePage()
http_OK,
if (pos) {
else {
Serial.print(data);
data += 5;
// Return home page
homePage();
else {
// Page not found
