Need help in trying to get calibration from 0 to 359 with LSM303DLH breakout
hi, so is this the right section to post for help request.
A help would be appreciated greatly.
So here is the code that I’m trying to run below
#include <LSM303DLH.h>
#include <Wire.h>
LSM303DLH compass;
  Wire.begin();
  compass.enableDefault();
//void LSM303DLH::calibrate(void)
      compass.calibrate();
      compass.read();
	int respond = 0;
	Serial.println("Hit any key when ready to calibrate.");
	//wait till R is pressed
	while ( respond == 0)
		while (Serial.available()==0);;
		while (Serial.available()>0)
		 	respond = Serial.read();
	Serial.println("Rotate board until Min and Max values are reched for all axis.");
        Serial.println("WHen calibration done press D...");
		 delay(3000);
	while (respond != 100)
		 //Loop till D is pressed
		 compass.read();
   		if (compass.m.x > compass.m_max.x)
     	 	  compass.m_max.x = compass.m.x;
  		if (compass.m.y > compass.m_max.y)
      	 	  compass.m_max.y = compass.m.y;
   		if (compass.m.z > compass.m_max.z)
    	 	  compass.m_max.z = compass.m.z;
   		if (compass.m.x < compass.m_min.x)
     	 	  compass.m_min.x = compass.m.x;
    		if (compass.m.y < compass.m_min.y)
      		  compass.m_min.y = compass.m.y;
    		if (compass.m.z < compass.m_min.z)
      		 compass.m_min.z = compass.m.z;
		//Display results
     		if (compass.a.x > compass.a_max.x)
     	 	  compass.a_max.x = compass.a.x;
  		if (compass.a.y > compass.a_max.y)
      	 	  compass.a_max.y = compass.a.y;
   		if (compass.a.z > compass.a_max.z)
    	 	  compass.a_max.z = compass.a.z;
   		if (compass.a.x < compass.a_min.x)
     	 	  compass.a_min.x = compass.a.x;
    		if (compass.a.y < compass.a_min.y)
      		  compass.a_min.y = compass.a.y;
    		if (compass.a.z < compass.a_min.z)
      		 compass.a_min.z = compass.a.z;
	 	Serial.print("Maxx: ");
  		Serial.print(compass.m_max.x);
  		Serial.print(" MaxY: ");
  		Serial.print(compass.m_max.y);
 		Serial.print(" MaxZ: ");
  	 	Serial.print(compass.m_max.z);
  	 	Serial.print("Minx: ");
 	 	Serial.print(compass.m_min.x);
  	 	Serial.print(" MinY: ");
  	 	Serial.print(compass.m_min.y);
  	 	Serial.print(" MinZ:: ");
 	 	Serial.println(compass.m_min.z);
  		Serial.print(compass.a_max.x);
  		Serial.print(compass.a_max.y);
  	 	Serial.print(compass.a_max.z);
 	 	Serial.print(compass.a_min.x);
  	 	Serial.print(compass.a_min.y);
 	 	Serial.println(compass.a_min.z);
	//D pressed -> end loop
	Serial.println("DONE");
	delay(2000);
so far, there is no error and it successfully uploaded to the Arduino Uno board and I even set up the circuit connections properly with LSM303DLH breakout (from sparkfun) and using the logic level converter.
So the problem is nothing is showing up in my terminal window session…
why is that?
is there a problem with what I’m doing or supposed to do something?
What not even the :- Hit any key when ready to calibrate.
  Serial.println ("Serial");
  Wire.begin();
  Serial.println ("Wire");
  Serial.println ("compass");
And now?
it successfully printed out “Serial” , “Wire”, “compass”
but I don’t know why it did not print me on the first code.
