Hey everyone, I’m currently working on creating a display robot for the upcoming Burning Man festival. I got stumped on the power systems amp relays and using interrupts. I’m using an Arduino Mega ADK, along with an 8 relay board hooked up to the Arduino.
We’re using delays because the relays aren’t fast, and they have to be done in a certain order. In addition, we need to give the equipment that’s attached to the relays time to power down before going to the next step.
The problem is I really want to implement this via interrupts, primarily for our most important functions, like the activity monitor, the rain monitor, and the fan functions. Here’s the code.
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 rtc; // To calculate the date and time functions for the main program
Setup the power system relays on the Arduino Mega
const int Relay01 = 39; // Across Generator relay 1:2
const int Relay02 = 37; // Across Generator relay 2:3
const int Relay03 = 35; // Across Generator relay 5:6
const int Relay04 = 33; // Amp 1
const int Relay05 = 31; // Amp 2
const int Relay06 = 29; // Amp 3
const int Relay07 = 27; // Cooling Fan
const int Relay08 = 25; // Night Lights
Setup the Input Monitoring Pins: NOTE - for test purposes, we're using
rainPin 3 as the shutdown pin during simulation, cause we do want to shut
down the system when it's raining!
const int activityPin = 2; // Activity Monitor pin on interrupt 2 - returns HIGH or LOW
const int rainPin = 3; // Rain Monitor pin on interrupt 3 - returns HIGH or LOW
const int temperaturePin = 21; // Temperature Monitor on interrupt 21 - returns HIGH or LOW
const int batteryPin = 4; // Battery Voltage check - on a scheduled time basis - returns HIGH or LOW
const int enginePin = 5; // Engine on or off check - returns HIGH or LOW
Setup our variables that are read in from the input pins
int val_activity = 0; // activity variable
int val_rain = 0; // rain variable
int val_temp = 0; // temperature variable
int val_battery = 0; // battery variable
int val_engine = 0; // engine variable
Setup our integer variables for the engine logic to start or shut it off.
These correspond to the amp relays on the generator engine. NOT the relays
on the 8 relay board!
int rel01;
int rel02;
int rel03;
Setup the Relay pins to output
pinMode(Relay01, OUTPUT);
pinMode(Relay02, OUTPUT);
pinMode(Relay03, OUTPUT);
pinMode(Relay04, OUTPUT);
pinMode(Relay05, OUTPUT);
pinMode(Relay06, OUTPUT);
pinMode(Relay07, OUTPUT);
pinMode(Relay08, OUTPUT);
Setup the 8 relay board all to HIGH. It's a negative logic board.
HIGH means the relay is OPEN. LOW means the relay is closed
digitalWrite(Relay01, HIGH);
digitalWrite(Relay02, HIGH);
digitalWrite(Relay03, HIGH);
digitalWrite(Relay04, HIGH);
digitalWrite(Relay05, HIGH);
digitalWrite(Relay06, HIGH);
digitalWrite(Relay07, HIGH);
digitalWrite(Relay08, HIGH);
Setup the Monitoring Pins to Input
pinMode(activityPin, INPUT);
pinMode(rainPin, INPUT);
pinMode(temperaturePin, INPUT);
pinMode(batteryPin, INPUT);
pinMode(enginePin, INPUT);
Setup the RTC Clock Function
#ifdef AVR
Wire.begin();
#else
Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino Due
#endif
rtc.begin();
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(__DATE__, __TIME__));
Setup the Serial Port
Attach the interrupts to test the system start and
system stop functions.
attachInterrupt(2, system_start, RISING);
attachInterrupt(3, system_stop, RISING);
//val_activity = digitalRead(activityPin); // read in the activity pin
// val_rain = digitalRead(rainPin); // read in the shutdown pin
//Serial.println(val_activity);
//Serial.println(val_rain);
// buttontest(); // The button test simply emulates our inputs into the robot.
void buttontest() {
if (val_activity == 1) {
system_start();
if (val_rain == 1) {
system_stop();
void system_start() {
digitalWrite(Relay01, LOW); // attached to generator relay 1 and 2 CLOSED
rel01 = 0; // set rel01 value to 0 to indicate state for fan function
digitalWrite(Relay02, HIGH); // attached to generator relay 2 and 3 OPEN
rel02 = 1; // set rel02 value to 1
digitalWrite(Relay03, HIGH); // attached to generator relay 5 and 6 OPEN
rel03 = 1;
digitalWrite(Relay04, LOW); // turn on Amp 1
digitalWrite(Relay05, LOW); // turn on Amp 2
digitalWrite(Relay06, LOW); // turn on Amp 3
digitalWrite(Relay08, LOW); // turn on lights for the night
void system_stop() {
digitalWrite(Relay04, HIGH); // shutdown Amp 1
digitalWrite(Relay05, HIGH); // shutdown Amp 2
digitalWrite(Relay06, HIGH); // shutdown Amp 3
digitalWrite(Relay01, HIGH); // attached to generator relay 1 and 2
rel01 = 1;
digitalWrite(Relay02, LOW); // attached to generator relay 2 and 3 CLOSED for shutdown
rel02 = 0;
digitalWrite(Relay03, LOW); // attached to generator relay 5 and 6 CLOSED for shutdown
rel03 = 0;
digitalWrite(Relay08, LOW); // leave the lights alone
The problem with this second version is, obviously, the relays blaze with complete disregard to the delays. I understand that the hardware interrupts disable the delay() function, and the Millis() function in order for it to function AS an interrupt. No problems understanding that. My problem is this:
Is there another way to implement a time delay when using a hardware interrupt? So far, all the examples I see using Millis involve blinking an LED. I’ve gone way beyond that.
Any advice is appreciated.
