i am having a little trouble with my sketch... mainly this part....
#include <UTFT.h> // used to interface with the TFT display
#include <UTouch.h> // used to interface with the touch controller on the TFT display
#include <avr/pgmspace.h>
#include <Wire.h>
#include <EEPROM.h>
#include "writeAnything.h"
#include <DS1307.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include "DHT.h"
#include <tinyFAT.h> // used to acess the SD card
#include <UTFT_tinyFAT.h> // used to read .raw images from the SD card
#include <SD.h> //Used to check for SD card
UTFT myGLCD(SSD1289,38,39,40,41); //Uncomment this line for the SSD1289 TFT Screen
UTouch myTouch (6,5,4,3,2); //Pins Used for the Touch screen
UTFT_tinyFAT myFiles(&myGLCD); // start up an instance to read images from the SD card
int mistingT1OnH, mistingT1OnM, mistingT1OnS, mistingT1OffH, mistingT1OffM, mistingT1OffS; //Misting Timer save settings #1
int mistingT2OnH, mistingT2OnM, mistingT2OnS, mistingT2OffH, mistingT2OffM, mistingT2OffS; //Misting Timer save settings #2
int timerAmPmOn, timerAmPmOff, timerAmPm1On, timerAmPm1Off, timerAmPm2On, timerAmPm2Off;
int timerHoursOn, timerMinsOn, timerSecsOn;
int timerHoursOff, timerMinsOff, timerSecsOff;
struct config_m1{
int mistingT1onh;
int mistingT1onm;
int mistingT1ons;
int mistingT1offh;
int mistingT1offm;
int mistingT1offs;
int timerAmPm1on;
int timerAmPm1off;}
misting1Settings;
struct config_m2{
int mistingT2onh;
int mistingT2onm;
int mistingT2ons;
int mistingT2offh;
int mistingT2offm;
int mistingT2offs;
int timerAmPm2on;
int timerAmPm2off;}
misting2Settings;
void SaveMisting1ToEEPROM(){
misting1Settings.mistingT1onh = int (mistingT1OnH);
misting1Settings.mistingT1onm = int (mistingT1OnM);
misting1Settings.mistingT1ons = int (mistingT1OnS);
misting1Settings.mistingT1offh = int (mistingT1OffH);
misting1Settings.mistingT1offm = int (mistingT1OffM);
misting1Settings.mistingT1offs = int (mistingT1OffS);
misting1Settings.timerAmPm1on = int (timerAmPm1On);
misting1Settings.timerAmPm1off = int (timerAmPm1Off);
EEPROM_writeAnything(30, misting1Settings);}
void SaveMisting2ToEEPROM(){
misting2Settings.mistingT2onh = int (mistingT2OnH);
misting2Settings.mistingT2onm = int (mistingT2OnM);
misting2Settings.mistingT2ons = int (mistingT2OnS);
misting2Settings.mistingT2offh = int (mistingT2OffH);
misting2Settings.mistingT2offm = int (mistingT2OffM);
misting2Settings.mistingT2offs = int (mistingT2OffS);
misting2Settings.timerAmPm2on = int (timerAmPm2On);
misting2Settings.timerAmPm2off = int (timerAmPm2Off);
EEPROM_writeAnything(60, misting2Settings);}
void ReadFromEEPROM()
EEPROM_readAnything(30, misting1Settings);
mistingT1OnH = misting1Settings.mistingT1onh;
mistingT1OnM = misting1Settings.mistingT1onm;
mistingT1OnS = misting1Settings.mistingT1ons;
mistingT1OffH = misting1Settings.mistingT1offh;
mistingT1OffM = misting1Settings.mistingT1offm;
mistingT1OffS = misting1Settings.mistingT1offs;
timerAmPm1On = misting1Settings.timerAmPm1on;
timerAmPm1Off = misting1Settings.timerAmPm1off;
EEPROM_readAnything(60, misting2Settings);
mistingT2OnH = misting2Settings.mistingT2onh;
mistingT2OnM = misting2Settings.mistingT2onm;
mistingT2OnS = misting2Settings.mistingT2ons;
mistingT2OffH = misting2Settings.mistingT2offh;
mistingT2OffM = misting2Settings.mistingT2offm;
mistingT2OffS = misting2Settings.mistingT2offs;
timerAmPm2On = misting2Settings.timerAmPm2on;
timerAmPm2Off = misting2Settings.timerAmPm2off;
void setTimerScreen()
if (timerPage==1){
printHeader("Set Misting Timer 1");
timerHoursOn = mistingT1OnH;
timerMinsOn = mistingT1OnM;
timerSecsOn = mistingT1OnS;
timerHoursOff = mistingT1OffH;
timerMinsOff = mistingT1OffM;
timerSecsOff = mistingT1OffS;
timerAmPmOn = timerAmPm1On;
timerAmPmOff = timerAmPm1Off;}
if (timerPage==2){
printHeader("Set Misting Timer 2");
timerHoursOn = mistingT2OnH;
timerMinsOn = mistingT2OnM;
timerSecsOn = mistingT2OnS;
timerHoursOff = mistingT2OffH;
timerMinsOff = mistingT2OffM;
timerSecsOff = mistingT2OffS;
timerAmPmOn = timerAmPm2On;
timerAmPmOff = timerAmPm2Off;}
myGLCD.setColor(56, 142, 142); //Draw comment box
myGLCD.fillRect(0, 123, 319, 125); //set time horizontal divider
myGLCD.fillRect(159, 28, 161, 123); //Center Divider
setFont (SMALL, 0, 255, 255, 0, 0, 0);
myGLCD.print("Sun", 17, 130);
myGLCD.print("Mon", 51, 130);
myGLCD.print("Tue", 84, 130);
myGLCD.print("Wed", 118, 130);
setFont (LARGE, 0, 255, 255, 0, 0, 0);
myGLCD.print("** On **", 17, 20);
myGLCD.print("** Off **", 170, 20);
setFont (LARGE, 255, 255, 255, 0, 0, 0);
if (timerHoursOn<10) //Set Timer On
{ myGLCD.printNumI(0, 2, 70);
myGLCD.printNumI(timerHoursOn, 18, 70);}
{ myGLCD.printNumI(timerHoursOn, 2, 70);}
if (timerMinsOn<10)
{ myGLCD.printNumI(0, 45, 70);
myGLCD.printNumI(timerMinsOn, 61, 70);}
{ myGLCD.printNumI(timerMinsOn, 45, 70);}
if (timerSecsOn<10)
{ myGLCD.printNumI(0, 88, 70);
myGLCD.printNumI(timerSecsOn, 104, 70);}
{ myGLCD.printNumI(timerSecsOn, 88, 70);}
if (timerAmPmOn==0)
{ myGLCD.print("AM", 124, 70);}
{ myGLCD.print("PM", 124, 70);}
if (timerHoursOff<10) //Set Timer Off
{ myGLCD.printNumI(0, 164, 70);
myGLCD.printNumI(timerHoursOff, 180, 70);}
{ myGLCD.printNumI(timerHoursOff, 164, 70);}
if (timerMinsOff<10)
{ myGLCD.printNumI(0, 207, 70);
myGLCD.printNumI(timerMinsOff, 223, 70);}
{ myGLCD.printNumI(timerMinsOff, 207, 70);}
if (timerSecsOff<10)
{ myGLCD.printNumI(0, 250, 70);
myGLCD.printNumI(timerSecsOff, 266, 70);}
{ myGLCD.printNumI(timerSecsOff, 250, 70);}
if (timerAmPmOff==0)
{ myGLCD.print("AM", 286, 70);}
{ myGLCD.print("PM", 286, 70);}
myGLCD.print(":", 32, 70);
myGLCD.print(":", 75, 70);
myGLCD.print(":", 194, 70);
myGLCD.print(":", 237, 70);
it compiles fine no error... but when its uploaded, the utft just gives me a blank white screen... but if i comment it out, then it load the screen just fine....
the "timerHoursOn" is the int = to the "mistingT1OnH" which is the int saved to eeprom...
am i doing something wrong? code looks right but its not working... if you need more info please let me know
the void setup and void loop was not included in the code...
