Need help - Lilypad Simblee sketch will not upload
Working on project using LilyPad Simblee and I cannot get the sketch to upload. The correct ports and boards seem to be selected, but I keep getting the error message below. Assistance would be greatly appreciated as I have a project due and I can't seem to get this going. Thanks.
Arduino: 1.8.5 (Windows 10), Board: "Simblee"
Sketch uses 28736 bytes (21%) of program storage space. Maximum is 131072 bytes.
Global variables use 2404 bytes of dynamic memory.
C:\Users\KSR\AppData\Local\Arduino15\packages\Simblee\hardware\Simblee\1.1.4/loader.bat RFDLoader.exe COM4 C:\Users\KSR\AppData\Local\Temp\arduino_build_332092 Connection.ino C:\Users\KSR\AppData\Local\Arduino15\packages\Simblee\hardware\Simblee\1.1.4/ C:\Users\KSR\AppData\Local\Arduino15\packages\Simblee\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/
Cannot open port. Is the right port selected, the cable connected, and power applied?
fail.......fail.......fail.......
An error occurred while uploading the sketch
option enabled in File -> Preferences.
(deleted)
Restarted computer and received same error message
Make sure you have the correct port for your Lilypad Simblee selected from the Tools > Port menu.
It is set to COM Port 4 which is the port indicated in my device manager. Is there any where else I should be checking for port settings?
Tried a different computer, uploaded ardunio1.8.7, connected board, installed ftdi chip drivers, restarted computer, and launched application...getting the same error message. Correct board and Port are indicated.
