Need help !!! (making an RC plane)
Hey, can someone plz guide me what i am doing wrong.
I wanted to send three servo inputs to another arduino using virtual wire.
I know that i am sending the inputs correctly as they appear on the serial print as i want them to but when i receive them, im only getting zeros.
Iv also tried the (for loop) for the array to store the data that i receive but had no luck with that too.
I have very little experience with arduino can someone plz explain me in detail what i can do.
thank you.
//transmitter
#include <VirtualWire.h>
int Rtrig;
char Rstr[5];
int Rtrig1;
char Rstr1[5];
int Rtrig2;
char Rstr2[5];
vw_setup(2000); // Bits per sec
Rtrig = analogRead(0);
Rtrig = map( Rtrig , 0 , 1023,1000 ,2000);
itoa(Rtrig, Rstr, 10);
const char *msg = Rstr;
Serial.println(msg);
vw_send((uint8_t *)msg, strlen(msg));
 vw_wait_tx();
Rtrig1 = analogRead(1);
Rtrig1 = map( Rtrig , 0 , 1023,1000 ,3000);
itoa(Rtrig1, Rstr1, 10);
const char *msg1 = Rstr1;
Serial.println(msg1);
vw_send((uint8_t *)msg1, strlen(msg1));
vw_wait_tx();
Rtrig2 = analogRead(2);
Rtrig2 = map( Rtrig2 , 0 , 1023,1000 ,2000);
itoa(Rtrig2, Rstr2, 10);
const char *msg2 = Rstr2;
Serial.println(msg2);
vw_send((uint8_t *)msg2, strlen(msg2));
 vw_wait_tx();
//reciever
#include <ServoTimer2.h>
ServoTimer2 myservo;
ServoTimer2 myservo1;
ServoTimer2 myservo2;
vw_rx_start(); // Start the receiver PLL running
myservo.attach(9);
myservo1.attach(10);
myservo2.attach(6);
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen))
int i;
for (i = 0; i < buflen; i++)
int val1;
int val2;
int val3;
val1 = atoi(buf[0]);
 val2 = atoi(buf[1]);
 val3 = atoi(buf[2]);
myservo.write(val1);
myservo1.write(val2);
myservo2.write(val3);
Serial.println(val1,DEC);
Serial.println(val2, DEC);
Serial.println(val3, DEC);
Maybe you need to call Serial.begin() about 8 or 9 more times.
You DEFINITELY need to use your tab key. Your indenting looks like sh*t.
Uh-huh, one, two... Is that how you count?
You send three messages. How many values are in each message?
You read one message. How many values are in that message?
Since you put ONE value in each message, how on earth do you think that the ONE message is going to contain THREE values?
buf[0] is NOT a string. You should NOT pass something that is not a string to a function that expects a string.
buf[1] is NOT a string. You should NOT pass something that is not a string to a function that expects a string.
buf[2] is NOT a string. You should NOT pass something that is not a string to a function that expects a string.
If you send the data in three messages it would be helpful if each message included an indication of which value it contained. You can do that with a structure:
struct SM {
byte channel;
unsigned int value;
} ServoMessage;
Then for each analog pin:
void sendMessage(byte channel, byte pin)
    ServoMessage.channel = channel;
    ServoMessage.value = map(analogRead(pin), 0, 1023, 1000, 2000);
    vw_send((uint8_t *)ServoMessage, sizeof SM);
    vw_wait_tx();
So your loop() becomes:
    sendMessage(0, Channel0Pin);
    sendMessage(1, Channel1Pin);
    sendMessage(2, Channel2Pin);
In your receiver:
        SM * ServoMessage = buf;
        switch (ServoMessage->channel)
        case 0:  // Channel 0
                myServo.writeMicroseconds(ServoMessage->value);
       case 1:  // Channel 1
                myServo1.writeMicroseconds(ServoMessage->value);
       case 2:  // Channel 2
                myServo2.writeMicroseconds(ServoMessage->value);
If you put your servo objects into an array you would not even need the 'switch' statement.
Thank you so much for explaining what i was doing wrong.
johnwasser:
really liked ur idea on sending an indicator…i tried ur code … i think i am missing something not so sure its giving me this error:
invalid cast from type ‘SM’ to type 'uint8_t* {aka unsigned char*}
I tried adding ‘&’ in " vw_send((uint8_t *)&ServoMessage, sizeof(SM));" which did the trick but i dont know whyit did. I remembered someone doing it in another forum. heres the code:
struct SM {
byte channel;
unsigned int value;
} ServoMessage;
    vw_send((uint8_t *)ServoMessage, sizeof(SM));
    vw_wait_tx();
vw_setup(2000);
In the receiver im getting this error as well. Although i have found a code that helped me… i would still like to know about what this error means. I really appreciate the help.
I started this project with almost no knowledge about arduino to learning a little about all the examples and the programming language itself. After spending a weeks only doing this iv manage to learn quite a bit…especially from the forums.
Heres the code for the plane if anyone wants ive have altered it to my need but the actual code was for a temperature sensor. All credits go to HazardsMind.
// Transmitter
char Array[20]; // store data
int X,Y; // for the joystick
int Z; // potentiometer
  Serial.println("Sending");
  vw_setup(2000);
  vw_set_tx_pin(12);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(5, OUTPUT);
  digitalWrite(7, LOW); // joystick ground
  digitalWrite(8,HIGH); // joystick Vcc
  digitalWrite(5,HIGH); // potentiometer Vcc
  pinMode(13, INPUT); //accel Z
  pinMode(14, INPUT); //accel Y
  pinMode(15, INPUT); //accel X
  X = analogRead(3) ; // X axis
  Y = analogRead(4) ; // Y axis
  Z = analogRead(2) ; // potentiometer
  sprintf(Array, "%d,%d,%d ",X,Y,Z);
  vw_send((uint8_t*)Array, strlen(Array));
  vw_wait_tx();
//receiver
//#define DEBUG_MODE
  pinMode(13,OUTPUT);
  pinMode(2,OUTPUT);
  pinMode(3,OUTPUT);
  myservo1.attach(6);
  myservo2.attach(9);
  vw_setup(2000);
  vw_set_rx_pin(11);
  vw_rx_start();
  digitalWrite(2, HIGH);// Vcc for servo
  digitalWrite(3, HIGH);// Vcc for servo
    digitalWrite(13, HIGH);
    int X = atoi(strtok(buf, ","));
    int Y = atoi(strtok(NULL,","));
    int esc = atoi(strtok(NULL," "));
X = map (X,  900, 0, 1000,3000 ); // Aleron
Y = map (Y , 900, 0, 1000,3000 ); // Rudder
 esc = map (esc , 0, 1023, 1000,2000 );
 #ifdef DEBUG_MODE
  Serial.print(X); // x axis
    Serial.print(", ");
    Serial.print(Y); // Y axis
    Serial.print(", ");
    Serial.print(esc); // for the ESC
  #endif
  myservo1.write(X); // Aleron
  myservo2.write(Y); // Rudder
  else digitalWrite(13, LOW); // No data received
I tried adding '&' in " vw_send((uint8_t *)&ServoMessage, sizeof(SM));" which did the trick but i dont know whyit did.
It is the address of the array that you want to be treated as though it was of type uint_8, so casting the address is the proper thing to do.
