As stated in the title, I have been trying to map out accelerometer data (specifically the y-axis) onto a servo output to make an auto leveling platform. I have been browsing the web for the past few nights trying to get this to work but I found the following code (below) to be the simplest way to pull this off. The weird thing is when working on this code earlier, it worked to a degree but since then all that happens is the servo up and down once and then does nothing. Any help form the community would be a life saver.
#include <Wire.h>
#include <Servo.h>
// i2c address of the mpu‐6050
const int MPU_ADDR = 0x68;
// variables
int16_t xAccel, yAccel, zAccel, temp, xGyro, yGyro, zGyro;
const int TILT = 9;
Servo myServo;
int val = 0;
// initialize the i2c library
Wire.begin();
// begin communication with the mpu‐6050
Wire.beginTransmission(MPU_ADDR);
// write to the power management register
Wire.write(0x6B);
// wake up the mpu‐6050
Wire.write(0);
// end communication with the mpu‐6050
Wire.endTransmission(true);
// initialize the serial port
myServo.attach(TILT);
// read the mpu data
//readMpuData();
* put your code for the digital letter scale here
// delay
//delay(500);
// write to the first data register
Wire.write(0x3B);
Wire.endTransmission(false);
// request fourteen register reads from the mpu‐6050
Wire.requestFrom(MPU_ADDR, 14, true);
// read registers 0x3B (ACCEL_XOUT_H) and 0x3C (ACCEL_XOUT_L)
xAccel = Wire.read() << 8 | Wire.read();
// read registers 0x3D (ACCEL_YOUT_H) and 0x3E (ACCEL_YOUT_L)
yAccel = Wire.read() << 8 | Wire.read();
// read registers 0x3F (ACCEL_ZOUT_H) and 0x40 (ACCEL_ZOUT_L)
zAccel = Wire.read() << 8 | Wire.read();
// read registers 0x41 (TEMP_OUT_H) and 0x42 (TEMP_OUT_L)
temp = Wire.read() << 8 | Wire.read();
// convert the temperature to celsius
temp = ((temp / 340.00) + 36.53);
// read registers 0x43 (GYRO_XOUT_H) and 0x44 (GYRO_XOUT_L)
xGyro = Wire.read() << 8 | Wire.read();
// read registers 0x45 (GYRO_YOUT_H) and 0x46 (GYRO_YOUT_L)
yGyro = Wire.read() << 8 | Wire.read();
// read registers 0x47 (GYRO_ZOUT_H) and 0x48 (GYRO_ZOUT_L)
zGyro = Wire.read() << 8 | Wire.read();
// print out the results
Serial.print("AX = "); Serial.print(xAccel); // X Raw Value
Serial.print(" | AY = "); Serial.print(yAccel); // Y Raw Value
Serial.print(" | AZ = "); Serial.print(zAccel); // Z Raw Value
Serial.print(" | C = "); Serial.print(temp);
Serial.print(" | GX = "); Serial.print(xGyro);
Serial.print(" | GY = "); Serial.print(yGyro);
Serial.print(" | GZ = "); Serial.println(zGyro);
//val = analogRead(yAccel);
yAccel = map(yAccel, 850, 11000, 0, 179);
myServo.write(yAccel);
delay(15);
void readMpuData()
