at the folowing code [code
unsigned long startMillis; //some global variables available anywhere in the program
unsigned long currentMillis;
const unsigned long period = 1000; //the value is a number of milliseconds
const byte ledPin = 13; //using the built in LED
Serial.begin(115200); //start Serial in case we need to print debugging info
pinMode(ledPin, OUTPUT);
startMillis = millis(); //initial start time
currentMillis = millis(); //get the current "time" (actually the number of milliseconds since the program started)
if (currentMillis - startMillis >= period) //test whether the period has elapsed
digitalWrite(ledPin, !digitalRead(ledPin)); //if so, change the state of the LED. Uses a neat trick to change the state
startMillis = currentMillis; //IMPORTANT to save the start time of the current LED state.
if i want to use miilis every 1 hour do i have to write const unsigned long period:
dataoikogarden:
so if let say i want for 6 hours for example i have to use :21600000 and so on is it correct ?
Ok now this is a different question.
The range of values of Arduino unsigned long is between 0-4,294,967,295. As long as your period is between these values you can use the value. If the value is outside this range, you will need to solve for this.
Correct, but by that time we're talking about almost 50 days. And by that time you also have a pretty big error. So a good time to rethink the approach if you want to time > 50 days
And for 1 hour, you can indeed use 1UL60UL60UL*1000UL or even 1 *60 * 60 * 1000UL
You will have to code to handle this. Do it for number of days, then do again for additional time. However, at this point you might want to consider using an RTC as it will keep time better and allow you to check longer time intervals.
