Need Help Of Expert Programmer to Shorten Code
Hey guys so I got the gas sensor (Mq2) and this is the default code which works great! however i need to shorten it because im squeezing it into codes for other sensors while still displaying the same output (Separate ammounts for each gas) can anyone give me a hand here??
/*******************Demo for MQ-2 Gas Sensor Module V1.0*****************************
Author:  Tiequan Shao: tiequan.shao[at]sandboxelectronics.com
         Peng Wei:     peng.wei[at]sandboxelectronics.com
Lisence: Attribution-NonCommercial-ShareAlike 3.0 Unported (CC BY-NC-SA 3.0)
Note:    This piece of source code is supposed to be used as a demostration ONLY. More
         sophisticated calibration is required for industrial field application.
                                                    Sandbox Electronics    2011-04-25
/************************Hardware Related Macros************************************/
#define         MQ_PIN                       (0)     //define which analog input channel you are going to use
#define         RL_VALUE                     (5)     //define the load resistance on the board, in kilo ohms
#define         RO_CLEAN_AIR_FACTOR          (9.83)  //RO_CLEAR_AIR_FACTOR=(Sensor resistance in clean air)/RO,
                                                     //which is derived from the chart in datasheet
/***********************Software Related Macros************************************/
#define         CALIBARAION_SAMPLE_TIMES     (50)    //define how many samples you are going to take in the calibration phase
#define         CALIBRATION_SAMPLE_INTERVAL  (500)   //define the time interal(in milisecond) between each samples in the
                                                     //cablibration phase
#define         READ_SAMPLE_INTERVAL         (50)    //define how many samples you are going to take in normal operation
#define         READ_SAMPLE_TIMES            (5)     //define the time interal(in milisecond) between each samples in
                                                     //normal operation
/**********************Application Related Macros**********************************/
#define         GAS_LPG                      (0)
#define         GAS_CO                       (1)
#define         GAS_SMOKE                    (2)
/*****************************Globals***********************************************/
float           LPGCurve[3]  =  {2.3,0.21,-0.47};   //two points are taken from the curve.
                                                    //with these two points, a line is formed which is "approximately equivalent"
                                                    //to the original curve.
                                                    //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
float           COCurve[3]  =  {2.3,0.72,-0.34};    //two points are taken from the curve.
                                                    //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000,  0.15)
float           SmokeCurve[3] ={2.3,0.53,-0.44};    //two points are taken from the curve.
                                                    //data format:{ x, y, slope}; point1: (lg200, 0.53), point2: (lg10000,  -0.22)
float           Ro           =  10;                 //Ro is initialized to 10 kilo ohms
  Serial.begin(9600);                               //UART setup, baudrate = 9600bps
  Serial.print("Calibrating...\n");
  Ro = MQCalibration(MQ_PIN);                       //Calibrating the sensor. Please make sure the sensor is in clean air
                                                    //when you perform the calibration
  Serial.print("Calibration is done...\n");
  Serial.print("Ro=");
  Serial.print(Ro);
  Serial.print("kohm");
  Serial.print("\n");
   Serial.print("LPG:");
   Serial.print(MQGetGasPercentage(MQRead(MQ_PIN)/Ro,GAS_LPG) );
   Serial.print( "ppm" );
   Serial.print("    ");
   Serial.print("CO:");
   Serial.print(MQGetGasPercentage(MQRead(MQ_PIN)/Ro,GAS_CO) );
   Serial.print("    ");
   Serial.print("SMOKE:");
   Serial.print(MQGetGasPercentage(MQRead(MQ_PIN)/Ro,GAS_SMOKE) );
   Serial.print("\n");
   delay(200);
/****************** MQResistanceCalculation ****************************************
Input:   raw_adc - raw value read from adc, which represents the voltage
Output:  the calculated sensor resistance
Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
         across the load resistor and its resistance, the resistance of the sensor
         could be derived.
float MQResistanceCalculation(int raw_adc)
  return ( ((float)RL_VALUE*(1023-raw_adc)/raw_adc));
/***************************** MQCalibration ****************************************
Input:   mq_pin - analog channel
Output:  Ro of the sensor
Remarks: This function assumes that the sensor is in clean air. It use
         MQResistanceCalculation to calculates the sensor resistance in clean air
         and then divides it with RO_CLEAN_AIR_FACTOR. RO_CLEAN_AIR_FACTOR is about
         10, which differs slightly between different sensors.
float MQCalibration(int mq_pin)
  int i;
  float val=0;
  for (i=0;i<CALIBARAION_SAMPLE_TIMES;i++) {            //take multiple samples
    val += MQResistanceCalculation(analogRead(mq_pin));
    delay(CALIBRATION_SAMPLE_INTERVAL);
  val = val/CALIBARAION_SAMPLE_TIMES;                   //calculate the average value
  val = val/RO_CLEAN_AIR_FACTOR;                        //divided by RO_CLEAN_AIR_FACTOR yields the Ro
                                                        //according to the chart in the datasheet
  return val;
/*****************************  MQRead *********************************************
Output:  Rs of the sensor
Remarks: This function use MQResistanceCalculation to caculate the sensor resistenc (Rs).
         The Rs changes as the sensor is in the different consentration of the target
         gas. The sample times and the time interval between samples could be configured
         by changing the definition of the macros.
float MQRead(int mq_pin)
  int i;
  float rs=0;
  for (i=0;i<READ_SAMPLE_TIMES;i++) {
    rs += MQResistanceCalculation(analogRead(mq_pin));
    delay(READ_SAMPLE_INTERVAL);
  rs = rs/READ_SAMPLE_TIMES;
  return rs;
/*****************************  MQGetGasPercentage **********************************
Input:   rs_ro_ratio - Rs divided by Ro
         gas_id      - target gas type
Output:  ppm of the target gas
Remarks: This function passes different curves to the MQGetPercentage function which
         calculates the ppm (parts per million) of the target gas.
int MQGetGasPercentage(float rs_ro_ratio, int gas_id)
  if ( gas_id == GAS_LPG ) {
     return MQGetPercentage(rs_ro_ratio,LPGCurve);
  } else if ( gas_id == GAS_CO ) {
     return MQGetPercentage(rs_ro_ratio,COCurve);
  } else if ( gas_id == GAS_SMOKE ) {
     return MQGetPercentage(rs_ro_ratio,SmokeCurve);
  return 0;
/*****************************  MQGetPercentage **********************************
         pcurve      - pointer to the curve of the target gas
Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
         of the line could be derived if y(rs_ro_ratio) is provided. As it is a
         logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
         value.
int  MQGetPercentage(float rs_ro_ratio, float *pcurve)
  return (pow(10,( ((rs_ro_ratio-pcurve[1])/pcurve[2]) + pcurve[0])));
Which parts do you not want to do anymore? Otherwise, the only shortening I see is some of the print outputs.
As CR said, reduce the printing, maybe like this
   Serial.print( "ppm    CO:");
   Serial.print( "ppm    SMOKE:");
   Serial.println( "ppm" );
Plus similar in setup(). The rest looks pretty good at a quick glance.
Rob
Well i wanted to physically shorten it (Ex remove commenting and see if there were functions that could shorten the writing) i figured it was a long shot i guess im going to have to paste it like that =(
You can take out the comments, change the print statements some, that won’t change the compiled length of 5810 bytes tho.
#define         MQ_PIN                       (0)
#define         GAS_LPG                      (0)
#define         GAS_CO                       (1)
float           Ro           =  10;
  Serial.println("Cal");
  Serial.println("Cal done");
  Serial.print(Ro);
  Serial.println("kohm");
   delay(200);
  int i;
  float val=0;
  return val;
  int i;
  float rs=0;
  return rs;
  return 0;
Why do you want to make a program less understandable?
Consistent spelling will help in future comprehension too.
I can see one bit that you might want to put into it’s own function (because the “same code” is essentially called twice):
  float val=0;
  // you also mispelled "calibration" in your constant, but you're consistent, so it's ok I guess
  val = MQSampleAnalog(mq_pin,CALIBARAION_SAMPLE_TIMES,CALIBRATION_SAMPLE_INTERVAL);
  return val;
  return MQSampleAnalog(mq_pin,READ_SAMPLE_TIMES,READ_SAMPLE_INTERVAL);
/*****************************  MQSampleAnalog *************************************
Inputs:  pin - analog channel
         times - how many times to sample
         interval - time between samples
Output:  sensor average
Remarks: ???
float MQSampleAnalog(int pin, int times, int interval)
  int i;
  float val=0;
  for (i=0;i<times;i++) {
    val += MQResistanceCalculation(analogRead(pin));
    delay(interval);
  val = val/times;
  return val;
Note that I haven’t tested this code, compiled it or anything, but it should be ok (or close enough that you can tweak it to work); it probably won’t save you any bytes in the binary, but it does shorten the code a bit.
:smiley:
If you're going to set "val" to the return of some function, why bother initialising it to zero?
In both these routines 'i' is used as a simple counter variable and it is faster, and produces smaller code, if you count down instead of up.
    float val = 0.0f;
    for ( int i = CALIBRATION_SAMPLE_TIMES; i--; )
    val /= CALIBRATION_SAMPLE_TIMES;
    val /= RO_CLEAN_AIR_FACTOR;
    return val;
    float rs = 0.0f;
    for ( int i = READ_SAMPLE_TIMES; i--; )
    rs /= READ_SAMPLE_TIMES;
    return rs;
EDIT: Yes I see the 'delay' (so it doesn't really matter here) - I'm just saying for completeness.
Flatten the code – make it so that functions which don’t absolutely have to exist are in-lined where they are called.
I can’t stand 3 or 4 line functions anyway, plus they gobble up both time and memory doing little more than shuffling data around.
I can't stand 3 or 4 line functions anyway
Oh my! We are going to have to agree to disagree on this one. For me, small functions are crucial - if it has more than a couple of flow control statements in it, it's too complex. The advantage you get by being able to give the function a nice long name that self documents the code is worth the price of admission alone.
He didn't ask for advice to make the program more politically-correct for the computer science nerd crowd, he asked how to make it smaller. Function calls EAT space and if they aren't required, get rid of them or mark the function "inline".
Small, Fast, Cheap. Pick two.
That's the rule with software design.
Mine's "Fast, cheap, reliable. Pick two"
AWOL:
There's that one, too, though in my Universe, if it isn't "reliable", it isn't code.
Not that, you know, my code always has that "0.00 bugs per KLOC" thing going for it ...
If its not reliable it may be cheap but it’s definitely not inexpensive.
lloyddean: If its not reliable it may be cheap but it's definitely not inexpensive.
That depends. Quickly written, poor quality code can be used for a proof of concept, to cost-effectively chose between two or more design alternatives.
In the "fast, cheap, reliable" universe, rapid prototyping can help you understand what's "fast" -- pick two or more different algorithms, rapidly prototyping them (that's "cheap"), pick the fast one. Take the "winning" algorithm and develop that. That gives you "fast" and "reliable" by tossing out any that were "slow" (and "unreliable" because you weren't coding for that in the first place).
This is where solid coding and naming conventions become critical -- the programmer(s) who is off laying down code as fast as they can type will often partition their work among the rest of the staff for re-writing. Lots of comments, truly meaningful names, and agreed-upon coding styles are essential. It's also why any programmer who can't touch-type needs to seek gainful employment in a different field.
I think it highly dependent upon the industries involved. Prototyping perhaps. But that's only part of product development.
I was in Gaming, Edutainment and Music software development 30+ years. Unreliable, cheap software was never inexpensive. Of course, other than budget overruns, it never hurt anyone.
Cheap, unreliable software in the Auto, Avionics and Medical industry is a whole different game.
Well, there's always "Marketing" when "Marketing" wants "something immediately" so they can show off the new product that's not even in the development schedule.
A bit like "vaporware", only with a little more substance. Like, "fogware".
I used a product once where my team could tell how far into the menu structure the developers got before quitting. The marketing glossies looked fantastic. The manual was great. The code? Incomplete!
Why? When I compiled it, it was less than 6K of code, much of which will be floating point subroutines that will be shared with other sensors anyway.
If the final program is too long, the best way to shorten it probably involves sharing more code between the different sensors, rather than making each individual sensor's code shorter.
Shortest & smallest
                                                     //normal operation
#define         GAS_LPG                      (0)
#define         GAS_CO                       (1)
  Serial.print(Ro);
  Serial.print("kohm\n");
   Serial.print( "ppm   CO: " );
   Serial.print( "ppm    SMOKE:" );
   Serial.print( "ppm\n" );
   delay(200);
         could be derived.
  float val=0;
  for (int i=0;i<CALIBARAION_SAMPLE_TIMES;i++) {            //take multiple samples
  return  (val/CALIBARAION_SAMPLE_TIMES)/RO_CLEAN_AIR_FACTOR;                        //divided by RO_CLEAN_AIR_FACTOR yields the Ro
  float rs=0;
  for (int i=0;i<READ_SAMPLE_TIMES;i++) {
  return rs/READ_SAMPLE_TIMES;
  return 0;
         value.
