need help on code explanation again, thanks
The code attached is for the Muiti_Obstacle Avoiding car project, the line : ‘#define AVOIDANCE_DELAY 1’ according to my understood, signed variable ‘AVOIDANCE_DELAY’ to pin 1?
but the call after: ‘for (int i = 0; i < AVOIDANCE_DELAY; i++) {’ seems doesn’t mean this, why?
Thanks
Adam
The code too long to be pasted in full, attached as a file.
#include <Wire.h> // Library for the BNO055
#include <Adafruit_Sensor.h> // Library for the BNO055
#include <Adafruit_BNO055.h> // Library for the BNO055
#include <utility/imumaths.h> // Library for the BNO055
#define ENABLE_A 5
#define MOTOR_A1 6
#define MOTOR_A2 4
// Define pins for Motor B
#define ENABLE_B 8
#define MOTOR_B1 7
#define MOTOR_B2 9
// Define pin for the QTR-1A Reflectance Sensor
#define IR_SENSOR A3
// Right sensor
#define TRIG_RIGHT A2
#define ECHO_RIGHT A1
// Right-center sensor
#define TRIG_RIGHT_CTR 12
#define ECHO_RIGHT_CTR 13
// Left-center sensor
#define TRIG_LEFT_CTR 10
#define ECHO_LEFT_CTR 11
// Left sensor
#define TRIG_LEFT 3
#define ECHO_LEFT 2
// Avoidance delay
// Number of 50ms increments we want
// to move forward after
// moving away from the object
/***** Try 1-5 depending on battery strength********/
/*---Helper-Function Prototypes---*/
// Motors
void disableMotors(void);
void enableMotors(void);
void goForward(void);
void goLeft(void);
void goRight(void);
void leftAvoid(void);
void rightAvoid(void);
void setupPins(void);
// Headings
void calculateHeadingError(void);
void correctHeading(void);
// Ultrasonic sensors
void doPingRight(void);
void doPingRightCtr(void);
void doPingLeftCtr(void);
void doPingLeft(void);
void getDistances(void);
// IR sensor
void readIRSensor(void);
// Obstacle avoidance
void avoidObstacles(void);
/*--------Module Variables--------*/
bool crossed_the_tape = false;
bool done = false;
// Keep track of the headings
int desired_heading;
int current_heading;
int heading_threshold = 60; // 120 degree cone until stage 2
int heading_error;
// Store sensor readings here
int ir_reflect_previous;
int ir_reflect_current;
// Try values between 100 and 600.
// Helps determine if the robot crosses the reflective tape
int threshold = 200;
// For Ultrasonic sensor distance readings
int distance_right;
int distance_rightctr;
int distance_leftctr;
int distance_left;
int limit = 9; // Inches, try 5-10 depending on battery strength
bool right_or_left = false; // Switch
// Keep track of the time in milliseconds
unsigned long start_time;
unsigned long time_elapsed_threshold = 2000;
Adafruit_BNO055 bno = Adafruit_BNO055(55);
/*----------Module Code-----------*/
void setup(void) {
  // Start the car
  setupPins();
  enableMotors();
  // Get initial readings on the IR sensor
  ir_reflect_previous = analogRead(IR_SENSOR);
  ir_reflect_current = ir_reflect_previous;
  // Initialize the orientation sensor
  if(!bno.begin()) {
    while(1);
  bno.setExtCrystalUse(true);
void loop(void) {
  // Stage 0 - before the robot enters the
  // multi-obstacle environment
  while(!crossed_the_tape) {
    delay(50);
    // Read desired heading
    sensors_event_t event;
    bno.getEvent(&event);
    desired_heading = event.orientation.x;
    goForward();
    readIRSensor();
  // Stage 1
    // Read all four HC-SR04 sensors
    getDistances();
    // Avoid any obstacle along the way
    avoidObstacles();
  heading_threshold = 10;
  // Capture the time
  start_time = millis();
  // Stage 2
  while(!done) {
    calculateHeadingError();
    // Correct the heading if needed
    if (abs(heading_error) <= abs(heading_threshold)){
      goForward();
    else {
      correctHeading();
      goForward();
    // Check to see if we are done
    if (((millis()) - start_time) > time_elapsed_threshold) {
      done = true;
  while(done) {
    disableMotors();
void avoidObstacles(){
  // Avoid any objects
  if ((distance_leftctr < limit) && (distance_rightctr < limit)){
    // Switch back and forth
    if (right_or_left) {
      rightAvoid();
    else {
      leftAvoid();
    right_or_left = !(right_or_left);
  else if((distance_left < limit) || (distance_leftctr < limit)) {
    rightAvoid();
  else if((distance_right < limit) || (distance_rightctr < limit)) {
    leftAvoid();
  else {
        goForward();
    else {
      correctHeading();
      goForward();
    // Check to see if we have crossed the tape
    readIRSensor();
    delay(50);
 void calculateHeadingError() {
  // Read the current heading
  current_heading = event.orientation.x;
  // Calculate the heading error
  heading_error = current_heading - desired_heading;
  if (heading_error > 180) {
      heading_error -= 360;
  if (heading_error < -180) {
      heading_error += 360;
 void correctHeading(){
  // Turn the vehicle until it is facing the correct
  // direction
  if (heading_error < -heading_threshold) {
    while (heading_error < -heading_threshold) {
      goRight();
      delay(4);
  else {
    while (heading_error > heading_threshold) {
      goLeft();
      delay(4);
void leftAvoid(){
  // Go to the left when an object is detected
  // on the right-side of the vehicle
  while((distance_right < limit) || (distance_rightctr < limit)) {
    goLeft();
    delay(4);
    doPingRight();
    doPingRightCtr();
  goForward();
    // Read the reflectance sensor
    ir_reflect_current = analogRead(IR_SENSOR);
    // Check to see if we have crossed over the reflective tape
    if ((ir_reflect_previous - ir_reflect_current) >= threshold) {
      // Update if we crossed the tape
      crossed_the_tape = true;
    // Update the previous reading
    ir_reflect_previous = ir_reflect_current;
    delay(50);
void readIRSensor() {
void rightAvoid(){
  // Go to the right when an object is detected
  // on the left-side of the vehicle
  while((distance_left < limit) || (distance_leftctr < limit)) {
    goRight();
    delay(4);
    doPingLeft();
    doPingLeftCtr();
  goForward();
    delay(50);
void setupPins(){
  // Configure motor pins
  pinMode(ENABLE_A, OUTPUT);
  pinMode(MOTOR_A1, OUTPUT);
  pinMode(MOTOR_A2, OUTPUT);
  pinMode(ENABLE_B, OUTPUT);
  pinMode(MOTOR_B1, OUTPUT);
  pinMode(MOTOR_B2, OUTPUT);
  // Configure HC-SR04 pins
  pinMode(TRIG_RIGHT, OUTPUT);
  pinMode(ECHO_RIGHT, INPUT);
  pinMode(TRIG_RIGHT_CTR, OUTPUT);
  pinMode(ECHO_RIGHT_CTR, INPUT);
  pinMode(TRIG_LEFT_CTR, OUTPUT);
  pinMode(ECHO_LEFT_CTR, INPUT);
  pinMode(TRIG_LEFT, OUTPUT);
  pinMode(ECHO_LEFT, INPUT);
CODE.01.ino (13.3 KB)
The comment for AVOIDANCE_DELAY seems quite clear – do you understand what it is saying?
In terms of what “#define AVOIDANCE_DELAY 1” means, “#define” is a pre-processor token. The pre-processor is a part of the C/C++ compilation pipeline (if you wanted to read up on it e.g. C preprocessor - Wikipedia). You can understand the “#define” token as telling the pre-processor: “Hey, each instance of X should be replaced with Y”.
So every time the pre-processor sees the macro AVOIDANCE_DELAY, it will substitute the value 1 in its place.
Hence:
  // blah
Can be read as:
for (int i = 0; i < 1; i++) {
  // blah
tomparkin:
Hence:
// blah
Can be read as:
 // blah
Thank you.
Have a good day.
'#define AVOIDANCE_DELAY 1' according to my understood, signed variable 'AVOIDANCE_DELAY' to pin 1?
That is not what #define does.
AVOIDANCE_DELAY has no data type. All that does is assign to AVOIDANCE_DELAY the value of 1. Then anywhere AVOIDANCE_DELAY is called, AVOIDANCE_DELAY is replaced by 1.
groundFungus:
Thank you,
the reason I thought that way cause of there were so many '#define' used in that code to assign the variable pins, such as:
#define ENABLE_B 8
#define MOTOR_B1 7
#define MOTOR_B2 9
Best.
Thanks for help.
The problem is solved.
Best
