need help on dynamic dns
Hi, I am making a webserver using IR and RCswitch library to operate my IR and RF devices. I am able to control dvices through LAN but when I m trying through Internet; I only get the few lines dispalyed basically the text lines but the buttons to opertae device do not load using Internet. I have tried using two different port and two different dynamic dns sites. I know how to port forward and is using dynamic dns for last for years for my IP cameras. I suspect two things that either my router is blocking these html based buttons or I have to put some delay in my sketch.As the sketch is working fine over the LAN I do not doubt the code.I will post the code little later. Had anybody had the same problem. I m using arduino Uno with Ws5100 ethernet shield.
prateek1972:
No problem here, but I don’t use dynamic dns. Post your code.
Probvlem resolved. I reduced 3 buttons and if statement from the sketch. Seems there was RAM issue.
