Need help on linear actuator control
Hi everyone,
I'm currently working on a project that require a linear movement in the actuator. I'm using Arduino Uno & 2A L298P motor shield.
I'm able to move shaft outward but I'm unable to get the shaft move inwards.
I used the following code to move the actuator outwards.
int motorPin1 = 5; int motorPin2 = 6; int motorPin3 = 7; int motorPin4 = 8; int delayTime = 150;
void setup() { pinMode(motorPin1, OUTPUT); pinMode(motorPin2, OUTPUT); pinMode(motorPin3, OUTPUT); pinMode(motorPin4, OUTPUT); }
digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, HIGH); digitalWrite(motorPin3, HIGH); digitalWrite(motorPin4, LOW);
delay(delayTime);
digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, HIGH); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, HIGH);
delay(delayTime);
digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, HIGH);
delay(delayTime);
digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, HIGH); digitalWrite(motorPin4, LOW);
delay(delayTime);
Datasheet of the actuator - http://sg.rs-online.com/web/p/electric-linear-actuators/4947234/
Thank you so much!
And your schematic? And the code tags that you would have read about if you could be arsed reading the how to use this forum sticky?
