need help on liquid crystal library
hello everyone,
i'm getting following errors while compiling the codes for my controller:
C:\Users\admin\Downloads\arduino-1.0.1-windows (2)\arduino-1.0.1\libraries\LiquidCrystal\LiquidCrystal.cpp: In member function 'void LiquidCrystal::initSPI(uint8_t)':
C:\Users\admin\Downloads\arduino-1.0.1-windows (2)\arduino-1.0.1\libraries\LiquidCrystal\LiquidCrystal.cpp:117: error: 'SPI' was not declared in this scope
C:\Users\admin\Downloads\arduino-1.0.1-windows (2)\arduino-1.0.1\libraries\LiquidCrystal\LiquidCrystal.cpp:120: error: 'SPI_CLOCK_DIV2' was not declared in this scope
C:\Users\admin\Downloads\arduino-1.0.1-windows (2)\arduino-1.0.1\libraries\LiquidCrystal\LiquidCrystal.cpp:124: error: 'SPI_MODE0' was not declared in this scope
C:\Users\admin\Downloads\arduino-1.0.1-windows (2)\arduino-1.0.1\libraries\LiquidCrystal\LiquidCrystal.cpp: In member function 'void LiquidCrystal::spiSendOut()':
C:\Users\admin\Downloads\arduino-1.0.1-windows (2)\arduino-1.0.1\libraries\LiquidCrystal\LiquidCrystal.cpp:403: error: 'SPI' was not declared in this scope
the liquid crystal.h was downloaded from Arduino Playground - LiquidCrystal Library
Put "#include <SPI.h>" before the include of the library, just as it is in the example.
i am having same problem for my project....
i had written <spi.h> but nothing worked
ahjnar:
Did you try the proper capitalization: <SPI.h>?
Thanx for the help. I'm also facing the same problem. I've tried all possible caps/without caps includes, but he error persists.
I tried these one by one:
#include<spi.h>
#include<SPI.h>
#include"spi.h"
#include"SPI.h"
Here is the line of code where there is error message:
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIV2);
Error message: 'SPI_CLOCK_DIV2' was not declared in this scope.
Kindly help me in this regard, i'm stuck in the project i need to deliver.
regards.
farrukhlodhi:
That constant should be defined by SPI.h. Perhaps if you showed all of your code someone could figure out why the declaration is not happening.
If you check the SPI.h , 'SPI_CLOCK_DIV2' is defind there.
so it means that your library is not added Properly. follow below thread it may help you.
http://forum.arduino.cc/index.php?topic=214675.msg1571278#msg1571278
