Need help on multiple bytes read of I2C interface
Hello~~~
I would like to modify this program used for mma7455(I2C) as the 'Multiple Bytes Read' mode of I2C interface.
The program can run normally, but only read one byte one time.
Thank you guys. :stuck_out_tongue:
#include <Wire.h>
#define ACCELEROMETER 0x1D //Address for Accelerometer
//REGISTERS
#define MODE_CONTROL 0x16 //Mode control register
#define PULSE_DET 0x1B //Pulse detection threshold limit value
#define X_OUT 0x06 //8 bit register containing value for X
#define Y_OUT 0x07 //8 bit register containing value for Y
#define Z_OUT 0x08 //8 bit register containing value for Z
#define DETECTION 0x0A //Detection source register
//VALUES
#define Z_PULSE 0x40 //Pulse detected on Z-axis
#define SENSEVALUE 0x25 //Default sensitivity level
//required setup function
Wire.begin();
accWrite(MODE_CONTROL, SENSEVALUE);
//required loop function
Serial.print("X: ");
Serial.print(accRead(X_OUT));
Serial.print(" Y: ");
Serial.print(accRead(Y_OUT));
Serial.print(" Z: ");
Serial.println(accRead(Z_OUT));
delay(100);
//function to write byte data into a register
void accWrite(byte address, byte data) {
Wire.beginTransmission(ACCELEROMETER);
Wire.send(address);
Wire.send(data);
Wire.endTransmission();
//function to read byte data from a register
unsigned int accRead(byte address){
byte val = 0x00;
Wire.send(address);
Wire.requestFrom(ACCELEROMETER, 1);
while (Wire.available() <= 0) { // wait for a value
Serial.print(address, HEX); // show which axis is being read
val = Wire.receive();
Serial.print("got: ");
Serial.println(val);
return val;
Change:-
to
Wire.requestFrom(ACCELEROMETER, 2);
You still have to read them one byte at at time because that's how they come.
Hi man~
Thanks for your advice.
As it's a 3-axis accelerometer, I change '1' to '3'.
But, using oscilloscope, the sequence is still 'One Byte Read':
Device address with Write Bit------write X_OUT address-------RS--------Device address with Read Bit-------------value stored in X_OUT.
Then, repit the operation for Y_OUT, and Z_OUT.....................
PS: Then, I changed the main loop:
delay(100);
TO....................
delay(100);
As the request quantity is 3, it should appear 3 values for X Y Z
But, on the serial monitor, only values of X appear.... =(
I really don't know why.....
please use the # button to present your code with appropiate tags,
that said, have you read - Arduino Playground - I2C - and - Wire - Arduino Reference -?
these pages describe the basics of I2C, a must read imho...
Do you have tried the Library Google Code Archive - Long-term storage for Google Code Project Hosting. ?
I used it on http://www.open-electronics.org/mma7455l-three-axis-digital-output-accelerometer/
