Need help on my project
Hello ,
I’m new here, and i don’t now if i’m posting in the right place but here goes.
i am creating a project for an automated watering system with an arduino nano, an Tiny RTC I2M module , a relay.
I started with only one watering schedule that consisted in once a day at a specific time, but i need to increase the watering for twice a day and i added another routine to the sketch and it does not work .
When i run the sketch only with the routine in green it works fine but when i add the part in red it simply does not do anything .
Can any one help me
//Criado por Nuno Protasio
//Sistema de rega temporizada
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
  Wire.begin();
  rtc.begin();
  if (! rtc.isrunning())
    Serial.println("RTC nao esta a trabalhar!");
  //Usar o pin que quiser, eu usei o pin 4
  pinMode(4, OUTPUT);
  DateTime now = rtc.now();
  Serial.print(now.year(), DEC);
  Serial.print('/');
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.day(), DEC);
  Serial.print(" (");
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  //O horario esta configurado para 24h
  //Pin 4 liga as 18:32 e desliga as 18:33
  if (now.hour() == 18 & now.minute() == 32 & now.second() == 0)
    digitalWrite(4, HIGH);
  else if (now.hour() == 18 & now.minute() == 33 & now.second() == 0)
    digitalWrite(4, LOW);
    //Aqui começa o novo programa
    //Pin4 liga as 18:05 e desliga as 18:07
  if (now.hour() == 18 & now.minute() == 37 & now.second() == 0)
  else if (now.hour() == 18 & now.minute() == 38 & now.second() == 0)
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
(deleted)
If the first if statement is true, what are the odds of the second one also being true? A snowball in hell on a hot day has a better chance.
What do you mean by that
He means, if the time now is 18:33:00, what are the chances that it is now also 18:37:00 ?
(deleted)
Nunomsp: ```  if (now.hour() == 18 & now.minute() == 32 & now.second() == 0)  {    digitalWrite(4, HIGH);  }
 else if (now.hour() == 18 & now.minute() == 33 & now.second() == 0)  {    digitalWrite(4, LOW);
     //Aqui começa o novo programa    //Pin4 liga as 18:05 e desliga as 18:07  if (now.hour() == 18 & now.minute() == 37 & now.second() == 0)  {    digitalWrite(4, HIGH);  }
I think you meant to use &&(boolean and) instead of &(bitwise AND). For more information see https://www.arduino.cc/en/Reference/BitwiseAnd and https://www.arduino.cc/en/Reference/Boolean
You have incorrectly nested your if clauses. Use apple-T (not sure what it is on widows) to auto-format your code. This helps make the nesting more obvious.
spycatcher2k: I already gave the solution in your OTHER post. >:(
Threads merged.
OP - To make coding on projects like this a lot easier on yourself - learn some fundamentals of coding structure. e.g. struct{} switch() and other tools.
#Define your 'constants' and pins up the top with meaningful names - then refer to them in the code. Break functional bits of code into functions() - which makes isolation and debugging a lot easier - along with future incremental development.
Good luck!
What really needs to happen here is that we need a struct for "watering schedule", and an array of them for the different schedules. You the iterate through them - if any are on, the water goes on.
This struct could include on time, off time, and a bit mask of pins that it controls. Bitwise-or the pin masks of every struct that is on now, and that tells you what pins to turn on.
