Need help on programming code
I did some code below and i tried run the code but cant because some error been detected which i couldn't understand. My task only to send binary data when a pushbutton is pressed.
int crankingPin = 3
int liftoffPin = 4
int upwardPin = 5
int downwardPin = 6
int turnleftPin = 7
int turnrightPin = 8
int forwardPin = 9
int backwardPin = 10
// initialize the serial communication:
// initialize the ledPin as an output:
pinMode(crankingPin, INPUT);
buttoncrankingState = digitalRead(crankingPin);
if (buttoncrankingState == HIGH)
Serial.write(8 , BIN);
this code not working.Pls anyone can rectifier it.PLS help me
In C++, every variable needs to have a type.
There is no type defined for buttoncrankingState. It should have "int " in front, to define the type.
You might also want to have an else clause, to be sure that the switch is working correctly.
You are not using the internal pull-up resistor. This implies that you have an external pull-down resistor with the switch. Is that true?
I didnt get what you trying to say about pull up resistor. But the program i change to be like below. Can you have a look my code?
int crankingPin = 3;
int liftoffPin = 4;
int upwardPin = 5;
int downwardPin = 6;
int turnleftPin = 7;
int turnrightPin = 8;
int forwardPin = 9;
int backwardPin = 10;
pinMode(liftoffPin, INPUT);
pinMode(upwardPin, INPUT);
pinMode(downwardPin, INPUT);
pinMode(turnleftPin, INPUT);
pinMode(turnrightPin, INPUT);
pinMode(forwardPin, INPUT);
pinMode(backwardPin, INPUT);
{ if
(digitalRead(crankingPin)==HIGH);
if(digitalRead(crankingPin)==HIGH);
The body of the statement (the code to be executed if the evaluation is true) is ;. That, effectively, means do nothing, regardless of whether the condition evaluates to true or not.
What did you have against storing the value for digitalRead in a variable?
You have a lot to learn about how the Arduino works with switches. http://arduino.cc/en/Tutorial/Button and http://arduino.cc/en/Tutorial/Debounce
Presuming that you get the hardware and code straightened out to properly detect a switch press, why do you want to write 8, in binary, to the serial port?
i want to transmit binary data and another arduino will receive the binary and execute certai routine(controlling motor speed)
