Need help on RGB LED pad.
Hi all, Im new in arduino and i have alot of questionmarks in my head, I hope somebody here are willing to answer my question =).
Im just decided to make a four combined 8x8 RGB LED as my FYP. Im know nothing about this and i have 2 main problem here
  1. how to adjust the RGB light to the color i want using PWM?
  2. how to make animation (any color) to the pad?
May i know what component i need at first,and what is the prosedure?
example: an arduino board(I saw alot of arduino board in the website,which 1 is the exactly i need,Arduino Duemilanove ? ?what is the different then ?
What is the different between SPARKFUN rgb matrix pad with other brand like LEDSEE, the price is cheaper than SPARKFUN 1 alot?
Im really appreciate for those who are willing to guide me =),or give me your msn,i will add u =)
what i would like to do is just same like this video
does somebody could give me some help ? i would really appreciate it
This is a quite complex project.
If you want to control the color of each individual LED it is the same as controlling 768 individual LED's, and not just on / off .
You should start reading about multiplexing, and google "Arduino LED matrix" or "Arduino RGB LED matrix" this should give you some starting ponits.
yea,so could u tell me what knowledge or info that i needed in order to complete this,what is the procedure?so that i can go google them or find more information =) ,so far i know PWM,multiplexing is needed in this project =)
may i know what is the different between ARDUINO NANO,ARDUINO MINI,ARDUINO ATMEGA and ARGUINO DUEMILANOVE ?????
Yep, you may!!
So now you know you need them start to look them up and understand them to start with:-
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
You may get to a state of knowledge where you find the project is too complex or too expensive for you to do. Then again you might not. :wink:
Hey,
I too have a few questions. I just bought a serial 8x8 matrix from Sparkfun and I am looking at how to connect it via the arduino to my computer. I am a bit overwhelmed but with the right basic set of instructions I think I will be fine. I just don't want to get cavalier and burn anything out.
I just need to get things connected, and find out how to communicate with this thing from max.
Any suggestions?
I got into the led from the arduino software finally. Now I just need to learn how to send it commands from max. I started a new thread about it in the software-interfacing section.
