Need help on why my code doesn't work
int venstre = 0;
int hoyre = 1;
void setup ()
Serial.print("LDR1: ");
Serial.print(analogRead(venstre));
Serial.print("LDR2: ");
Serial.print(analogRead(hoyre));
int venstreVerdi = analogRead(venstre);
int hoyreVerdi = analogRead(hoyre);
if(venstreVerdi > hoyreVerdi) {
#include <Servo.h>
Servo myservo;
myservo.attach(9);
myservo.write(140); // sving til venstre
void loop() {}
} //void setup slutt
}//slutt if
else if(hoyreVerdi > venstreVerdi) {
#include <Servo.h>
Servo myservo;
myservo.attach(9);
myservo.write(40); // set servo til høyre
void loop() {}
}//else if slutt
else {
#include <Servo.h>
Servo myservo;
myservo.attach(9);
myservo.write(90); // set servo to mid-point
void loop() {}
}// slutt else4
}//void loop slutt
Hi, please read this : http://forum.arduino.cc/index.php/topic,148850.0.html
Number 7 on that page is about "Code tags", if you use those, we can read the sketch.
You can use only one setup() and one loop() function. I think I see 4 of them is your sketch.
This should be ahead of setup() and loop()
#include <Servo.h>
Servo myservo;
Have you written a sketch before ? Could you start with the basic "Blink" example to blink a led ?
What are the errors given? By the way, please use
code tags.
I can't even list the issues because I have no idea what you did want to make...
Please learn basic programming in C++ because your code is utterly bad, you just will keep asking people to resolve your problems if you don't.
Try this instead :
#include <Servo.h>
const int LDR1_pin = 2;
const int LDR2_pin = 3;
Servo servo;
  servo.attach(9);
  servo.write(0);
  int LDR1_val = analogRead(LDR1_pin);
  int LDR2_val = analogRead(LDR2_pin);
  Serial.println("LDR1: " + LDR1_val);
  Serial.println("LDR2: " + LDR2_val);
  if (LDR1_val > LDR2_val)
    servo.write(140);
    servo.write(90);
