Just getting started with my first long-term project. I keep getting lost a bit in terminology and techniques on how I can properly power my set up. I know my UNO is powered by 5-12v and has a output of 5v to anything connected.
I am connecting 3 Meanwell ELN-60 (http://www.meanwell.com/search/eln-60/default.htm) to 3 separate CREE LED strings. For these strings to be dimmable, they require an additional 0-10v power supply to be attached. Here lies my question:
How can I turn this into a ~1 plug solution? Right now I would have 3 AC plugs for the drivers, 3 for the dimming functionality, one for the UNO, and a few others for various additional components.
Is there a way to power all of these and just regulate voltages down when needed so that I don't need 2 power strips just for my LEDs?
Side Note: This is all going on into an aquarium controller. I know there are a lot of tutorials around and have done a lot of searching and researching already but no one seems to address this issue. Not sure if there is a solution or not but any help is much appreciated.
The data sheet on the ELN-60 says that the dimmer can be controlled using PWM. I think I'd explore that, and build a single power supply for the rest. I'm betting an old ATX power supply could be used for all the DC components for an easy(-ish) solution. Or if you want to get your hands a bit more dirty, you could certainly build a single 110VAC power supply that has the exact AC and DC rails you need... be careful playing with mains voltage, though. A power strip may not be that bad when you consider the implications of a faulty homebrew 110VAC solution.
djjoshuad:
That is actually something I have missed in the datasheet so thanks for pointing that out. I do not have the drivers yet so I cannot really test but further down in the datasheet it mentions a 10v PWM is required thus, I assume this is why people connect an additional 10v supply in order to get the full dimming functionality. For example:
I have looked into using an ATX supply a bit and it seems like I might go that route. It is a little intimidating though considering the level of power coming from the supply but it seems like there is enough guidance out there.
