I've been trying to implement my TDS sensor in my mesh network.
This code is working with just the sensor and no mesh integration.
#define TdsSensorPin 4
#define VREF 1.1 // analog reference voltage(Volt) of the ADC
#define SCOUNT 30 // sum of sample point
int analogBuffer[SCOUNT]; // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0, copyIndex = 0;
float averageVoltage = 0, tdsValue = 0, temperature = 25;
pinMode(TdsSensorPin, INPUT);
static unsigned long analogSampleTimepoint = millis();
if (millis() - analogSampleTimepoint > 40U) //every 40 milliseconds,read the analog value from the ADC
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin); //read the analog value and store into the buffer
analogBufferIndex++;
if (analogBufferIndex == SCOUNT)
analogBufferIndex = 0;
static unsigned long printTimepoint = millis();
if (millis() - printTimepoint > 800U)
for (copyIndex = 0; copyIndex < SCOUNT; copyIndex++)
analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
averageVoltage = getMedianNum(analogBufferTemp, SCOUNT) * (float)VREF / 1024.0; // read the analog value more stable by the median filtering algorithm, and convert to voltage value
float compensationCoefficient = 1.0 + 0.02 * (temperature - 25.0); //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
float compensationVolatge = averageVoltage / compensationCoefficient; //temperature compensation
tdsValue = (133.42 * compensationVolatge * compensationVolatge * compensationVolatge - 255.86 * compensationVolatge * compensationVolatge + 857.39 * compensationVolatge) * 0.5; //convert voltage value to tds value
Serial.print("voltage:");
Serial.print(averageVoltage,2);
Serial.print("V ");
Serial.print("TDS----Value:");
Serial.print(tdsValue, 0);
Serial.println("ppm");
int getMedianNum(int bArray[], int iFilterLen)
int bTab[iFilterLen];
for (byte i = 0; i < iFilterLen; i++)
bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++)
for (i = 0; i < iFilterLen - j - 1; i++)
if (bTab[i] > bTab[i + 1])
bTemp = bTab[i];
bTab[i] = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0)
bTemp = bTab[(iFilterLen - 1) / 2];
bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
This is my integration with mesh. The getReadings function is executing and I get the print statements but the output is wrong plus I don't get the receviedCallback output.
#include "painlessMesh.h"
#include <Arduino_JSON.h>
#include <OneWire.h>
// MESH Details
#define MESH_PREFIX "Water Monitor Station" //name for your MESH
#define MESH_PASSWORD "somethingSneaky" //password for your MESH
#define MESH_PORT 5555 //default port
int nodeNumber = 1;
String readings;
Scheduler userScheduler; // to control your personal task
painlessMesh mesh;
void sendMessage() ; // Prototype so PlatformIO doesn't complain
String getReadings(); // Prototype for sending sensor readings
int getMedianNum ();
//Create tasks: to send messages and get readings;
Task taskSendMessage(TASK_SECOND * 5 , TASK_FOREVER, &sendMessage);
int i, j, bTemp;
bTemp = bTab[i];
return bTemp;
String getReadings () {
Serial.print("V ");
JSONVar jsonReadings;
int voltage = (averageVoltage,2);
int tds = (tdsValue, 0);
jsonReadings["node"] = nodeNumber;
jsonReadings["voltage"] = voltage;
jsonReadings["tds"] = tds;
readings = JSON.stringify(jsonReadings);
return readings;
void sendMessage () {
String msg = getReadings();
mesh.sendBroadcast(msg);
// Needed for painless library
void receivedCallback( uint32_t from, String &msg ) {
Serial.printf("Received from %u msg=%s\n", from, msg.c_str());
JSONVar myObject = JSON.parse(msg.c_str());
int node = myObject["node"];
int voltage = myObject["voltage"];
int tds = myObject["tds"];
Serial.print("Node: ");
Serial.println(node);
Serial.print("voltage: ");
Serial.print(voltage);
Serial.print("tds: ");
Serial.print(tds);
void newConnectionCallback(uint32_t nodeId) {
Serial.printf("New Connection, nodeId = %u\n", nodeId);
void changedConnectionCallback() {
Serial.printf("Changed connections\n");
void nodeTimeAdjustedCallback(int32_t offset) {
Serial.printf("Adjusted time %u. Offset = %d\n", mesh.getNodeTime(),offset);
//mesh.setDebugMsgTypes( ERROR | MESH_STATUS | CONNECTION | SYNC | COMMUNICATION | GENERAL | MSG_TYPES | REMOTE ); // all types on
mesh.setDebugMsgTypes( ERROR | STARTUP ); // set before init() so that you can see startup messages
mesh.init( MESH_PREFIX, MESH_PASSWORD, &userScheduler, MESH_PORT );
mesh.onReceive(&receivedCallback);
mesh.onNewConnection(&newConnectionCallback);
mesh.onChangedConnections(&changedConnectionCallback);
mesh.onNodeTimeAdjusted(&nodeTimeAdjustedCallback);
userScheduler.addTask(taskSendMessage);
taskSendMessage.enable();
// it will run the user scheduler as well
mesh.update();
Any help is appreciated.
