Need Help PLZ. Getting error message
#include <Adafruit_CircuitPlayground.h>
#include <Adafruit_Circuit_Playground.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeMonoOblique9pt7b.h>
#include <DHT.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define sensor A0;
#define DHTPIN 2 // Digital pin 2
#define DHTTYPE DHT11; // DHT 11
#define int gasLevel = 0; //int variable for gas level
#define String quality ="";
#define DHT dht(DHTPIN, DHTTYPE);
#define void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
display.setTextColor(WHITE);
display.setTextSize(1);
display.setFont();
display.setCursor(0, 43);
display.println("Temp :");
display.setCursor(80, 43);
display.println(t);
display.setCursor(114, 43);
display.println("C");
display.setCursor(0, 56);
display.println("RH :");
display.setCursor(80, 56);
display.println(h);
display.setCursor(114, 56);
display.println("%");
void air_sensor()
gasLevel = analogRead(sensor);
if(gasLevel<181){
quality = " GOOD!";
else if (gasLevel >181 && gasLevel<225){
quality = " Poor!";
else if (gasLevel >225 && gasLevel<300){
quality = "Very bad!";
else if (gasLevel >300 && gasLevel<350){
quality = "ur dead!";
else{
quality = " Toxic";
display.setCursor(1,5);
display.setFont();
display.println("Air Quality:");
display.setCursor(20,23);
display.setFont(&FreeMonoOblique9pt7b);
display.println(quality);
pinMode(sensor,INPUT);
dht.begin();
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
display.clearDisplay();
display.setTextSize(2);
display.setCursor(50, 0);
display.println("Air");
display.setCursor(23, 20);
display.println("Qulaity monitor");
display.display();
delay(1200);
display.setCursor(20, 20);
display.println("BY Abid");
display.display();
air_sensor();
sendSensor();
display.display();
There is an error message on the line: "void setup () {". The error message says "expected constructor, destructor or type conversion before ";" token. It's on the arduino IDE, not c++.
Oops
Please remember to use code tags when posting code
More oops.
No, the C++ compiler is generating these errors.
That one's a nasty one
You should remove these #define. Not the whole line just #define:
#define sensor A0;
What do I do to fix the code ? What lines need fixing
Just about everything, between
And
void air_sensor()
And then you need to figure out where the setup function ends, and the loop function starts.
But then
sensor A0;
Makes even less sense :wink:
Yes. I realized my copypasta error. :rofl:
with
any
kind of "please" "plz" and similar words in the headline
you
annoy
users "OMG just another one of those guys that is in a hurry for "write my code"
Yes I’m very much in a hurry :rofl::rofl::rofl:
bruh help us then, literally due in two days,, idk how to fix it :wink: :shushing_face: :stuck_out_tongue_winking_eye: :crazy_face:
how do we fix it ? dawg this thing is due in 2 days. I hate computer science. Help a young brotha out. H
As mentioned, remove the inappropriate #defines.
Work through it.
Report your progress, using code tags
(I'm not entirely sure I know what a "brotha" is, young or otherwise)
Nope, didn't get any of that.
ight thanks cuh, you a real one, ona dead locs. :100:
I think by "how do we fix it?" the OP means us.
You can start by changing the following lines from:
#define sensor A0;
to:
#define sensor A0
String quality ="";
void sendSensor()
thx dawg, you an og, cuhhh. :point_right: :point_left:
Still a solid "nope"
We speak English here.
