Need Help plz on a counter with shift registers
Hi, im really new to the arduino as well as the shift registers 74HC595. I believe that i have issues with setting up the shift registers as I am using three of them but im not sure if they are properly set up or just burnt out. My first 2 shift registers were set up correctly but when i placed my third one up by connecting the overload of shift register #2 to the data pin of shift register #3 the 2nd 7 segment display stopped displaying numbers properly. I connected all of the latch and clock pins from shift register #3 to shift register #2 and im not sure if that is the issue as maybe ur suppose to connect them to shift register #1? I'd really appreciate the help as it is no longer counting and the numbers on my 7 segment displays are just displaying 8. Here is my coding if it is incorrect as well. Thank you very much.
int dataPin1 = 5; int latchPin1 = 6; int clockPin1 = 7; int sensor = A0; int count1 = 0; int count2 = 0; int count3 = 0;
void setup() { //Configure each IO Pin pinMode(dataPin1, OUTPUT); pinMode(latchPin1, OUTPUT); pinMode(clockPin1, OUTPUT); Serial.begin(9600); }
void loop() { int sensorvalue = analogRead(sensor); if (sensorvalue > 600) { count1++; } if (count1 == 10) { count1 = 0; count2++; } if (count2 == 10) { count2 = 0; count3++; } if (count3 == 10) { count3 = 0; } if(sensorvalue > 600) { Serial.print ("count1 = "); Serial.println(count1); Serial.print ("count2 = "); Serial.println(count2); Serial.print ("count3 = "); Serial.println(count3); delay (200); }
digitalWrite(latchPin1, LOW); if (count3 == 0) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x3F); } if (count3 == 1) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x06); } if (count3 == 2) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x5b); } if (count3 == 3) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x4F); } if (count3 == 4) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x66); } if (count3 == 5) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x6D); } if (count3 == 6) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x7D); } if (count3 == 7) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x07); } if (count3 == 8) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x7F); } if (count3 == 9) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x6F); } if (count2 == 0) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x3F); } if (count2 == 1) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x06); } if (count2 == 2) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x5b); } if (count2 == 3) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x4F); } if (count2 == 4) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x66); } if (count2 == 5) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x6D); } if (count2 == 6) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x7D); } if (count2 == 7) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x07); } if (count2 == 8) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x7F); } if (count2 == 9) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x6F); }
if (count1 == 0) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x3F); } if (count1 == 1) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x06); } if (count1 == 2) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x5B); } if (count1 == 3) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x4F); } if (count1 == 4) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x66); } if (count1 == 5) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x6D); } if (count1 == 6) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x7D); } if (count1 == 7) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x07); } if (count1 == 8) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x7F); } if (count1 == 9) { shiftOut(dataPin1, clockPin1, MSBFIRST, 0x6F); } digitalWrite(latchPin1, HIGH); }
