Need help: Problem creating new files on a SD card
I just did a test using a UNO-3 where I wrote data to one file, closed it and started with a new one.
The test sketch created file t-00000.dat, t-00001.dat and t-00002.dat. But when trying to open t-00003.dat it failed:
17:41:40.035 -> File size: 164352
17:41:40.555 -> Closing file
17:41:40.555 -> t-00002.dat
17:41:40.555 -> Free ram=909
17:41:40.595 -> ERROR opening file: t-00003.dat
17:41:40.635 -> Free ram=909
17:41:40.635 -> ERROR opening file: t-00004.dat
17:41:40.675 -> Free ram=909
17:41:40.715 -> Free ram=909
17:41:40.715 -> ERROR opening file: t-00005.dat
17:41:46.675 -> ERROR opening file: t-00099.dat
17:41:46.715 -> Free ram=909
17:41:46.715 -> Test completed!!
I do not understand why. It's a 32 Gb card formatted as advised on this forum. Most of the space on the card is unused.
After the test I modified the sketch so that the filename is s-000000.dat, uploaded it and now it continue to create data on the card.
Why does it behave like this?
The test sketch:
#include <SPI.h>
#include <SD.h>
 * SD card
 * MOSI: pin 11
 * MISO: pin 12
 * SCK : pin 13
 * CS  : pint 10
const uint8_t chipSelect = 10;
File csvFile;
int freeRam()
  extern int __heap_start, *__brkval;
  int v;
  return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
void printFreeRam()
  Serial.print(F("Free ram="));
  Serial.println(freeRam());
 * Setup function.
  Serial.println(F("\n\n\nInitialzing..."));
  printFreeRam();
  // Initial SD card.
  Serial.println(F("Initializing SD card"));
  if (!SD.begin(chipSelect)) {
    Serial.println(F("Initialization failed!"));
    while (true) ;
  Serial.println(F("Initialization done."));
  Serial.println(F("Ready!"));
  printFreeRam();
 * Main loop function.
  char    filename[14];
  for (int fileNumber = 0; 100 > fileNumber; fileNumber++) {
    // Open a file.
    printFreeRam();
    sprintf_P(filename, PSTR("t-%05.5d.dat"), fileNumber);
    csvFile = SD.open(filename, FILE_WRITE);
    if (csvFile) {
      unsigned long   fsize;
      int             x1, x2, x3, x4;
      char            data[60];
      Serial.print(F("Writing to file: "));
      Serial.println(filename);
      printFreeRam();
      for (int i = 0; 10000 > i; i++) {
        x1 = random(1, 100);
        x2 = random(1, 1000);
        x3 = random(1, 1000);
        x4 = random(1, 10000);
        sprintf_P(data, PSTR("%d;%d;%d;%d;%d"), i, x1, x2, x3, x4);
        csvFile.println(data);
        fsize = csvFile.size();
        Serial.print(F("Line: "));
        Serial.print(1 + i);
        Serial.print(F(", file size: "));
        Serial.println(fsize);
        delay(100);
      Serial.println(F("Closing file "));
      Serial.println(csvFile.name());
      csvFile.close();
      Serial.print(F("ERROR opening file: "));
      printFreeRam();
  Serial.println(F("Test completed!!"));
  while (true) ;
Tried a different SD card adapter but without success. It can create a few files but then it start failing opening a new file.
Sometime I can create up to 17 files (max) and sometime only one before the problem start.
When trying to reset the controller it cannot initialize the SD card. Need to power it off and on again to make it work.
Would appreciate some feedback/suggestions on this. Thanks.
