i am using RF 433 transmitter and receiver to send and receive data. i am sending soil moisture sensor data to receiver side
here is transmitter code
#include <VirtualWire.h>
// LED's
const int ledPin = 13;
// Sensors
const int Sensor1Pin = A0;
// const int Sensor2Pin = 3;
int Sensor1Data;
// char Sensor1CharMsg[4];
// Trying to use 5 instead to fit trailing null char
// go back to 4 if this does not work.
char Sensor1CharMsg[5];
// PinModes
// LED
pinMode(ledPin,OUTPUT);
// Sensor(s)
pinMode(Sensor1Pin,INPUT);
// for debugging
// VirtualWire setup
vw_setup(300); // Bits per sec
// Read and store Sensor 1 data
Serial.print("Moisture Sensor Value:");
Serial.println(analogRead(1));
Sensor1Data = analogRead(Sensor1Pin);
// Convert integer data to Char array directly
itoa(Sensor1Data,Sensor1CharMsg,10);
// DEBUG
Serial.print("Sensor1 Integer: ");
Serial.print(Sensor1Data);
Serial.print(" Sensor1 CharMsg: ");
Serial.print(Sensor1CharMsg);
Serial.println(" ");
// END DEBUG
digitalWrite(13, true); // Turn on a light to show transmitting
vw_send((uint8_t *)Sensor1CharMsg, strlen(Sensor1CharMsg));
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(13, false); // Turn off a light after transmission
delay(200);
} // END void loop...
Receiver code
// LED's
int ledPin = 13;
// Sensors
int Sensor1Data;
// RF Transmission container
// sets the digital pin as output
pinMode(ledPin, OUTPUT);
// VirtualWire
// Initialise the IO and ISR
// Required for DR3100
vw_set_ptt_inverted(true);
// Bits per sec
vw_setup(2000);
// Start the receiver PLL running
vw_rx_start();
} // END void setup
void loop(){
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
// Non-blocking
if (vw_get_message(buf, &buflen))
int i;
// Turn on a light to show received good message
// Message with a good checksum received, dump it.
for (i = 0; i < buflen; i++)
// Fill Sensor1CharMsg Char array with corresponding
// chars from buffer.
Sensor1CharMsg[i] = char(buf[i]);
// Null terminate the char array
// This needs to be done otherwise problems will occur
// when the incoming messages has less digits than the
// one before.
Sensor1CharMsg[buflen] = '\0';
// Convert Sensor1CharMsg Char array to integer
Sensor1Data = atoi(Sensor1CharMsg);
// DEBUG
Serial.print("Sensor 1: ");
Serial.println(Sensor1Data);
// END DEBUG
// Turn off light to and await next message
