Need help programming a led rgb strip
Hi, i need some help to programming a led rgb strip,
i want to use 3 micro switch as a sensor and wen a click in some of theme a color turn on and turn off.
example:
click button 1, red turn on, click again button 1 red turns off.
I’m noob programming arduino so please help me, really need it :sob: .
This is not a difficult job. What Led strip are you useing, What Arduino are you useing, what is your budget?
It should not take more than a hour or two to sort this out depending on the driver for the LED strip.
Cheers Pete.
