need help programming value of proximity sensor to sweep servo arm
Not getting anywhere on Adafruit. So, I'm going to continue here. I tried 2 Futaba servos and get the same response. The servo moves maybe an 8th of an inch. Almost like the servos is seized up. Pull it from the VCC and it moves freely. Connect VCC again, it seizes up.
So, my question is did I program it correctly to sweep the arm from Pos A to Pos B? Or did I just give it an output the same as the led?
/*  Created by Nick Sebring: November 2017
    This sketch is designed to activate a barcode reader by moving a chart in front of
    the VCNL4010 I2C Proximity sensor.  Thus triggering the servo to move a magnet over the sensor
    in the handle of the barcode reader, activating the barcode readers infrared scanner.  Thus avoiding
    to reach across my desk and having to pull the trigger.  How lazy can us humans be?   Hahahaha
    The SCL and SDA are connected to #0 & 2 of the 5V Trinket
    Adding the refresh for the servo
#include "Adafruit_SoftServo.h"
#include "Adafruit_VCNL4010.h"
#define SERVOPIN 4   // Servo control line (WHITE) on Trinket Pin #4
Adafruit_SoftServo tinyServo;  //creates servo object
const int ledPin = 1;// LED on pin 1 to notify servo sketch is working
Adafruit_VCNL4010 vcnl;
  // Set up the interrupt that will refresh the servo for us automagically
  OCR0A = 0xAF;            // any number is OK
  TIMSK |= _BV(OCIE0A);    // Turn on the compare interrupt (below!)
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);// Set led off at start-up
  tinyServo.attach(SERVOPIN);   // attaches the servo
  //tinyServo.write(45);
  //delay(15);                    // Wait 15ms for the servo to reach the position
  if (! vcnl.begin()) {
    while (1);
  if (vcnl.readProximity() > 2150)//2125 seems to be ideal without plastic cover
    tinyServo.write(25);
    digitalWrite(ledPin, HIGH);
    // delay(15);                              // waits 15ms for the servo to reach the position
    tinyServo.write(160);
    //delay(15);                              // waits 15ms for the servo to reach the position
  // Suggested by Adafruit
  // We'll take advantage of the built in millis() timer that goes off
  // to keep track of time, and refresh the servo every 20 milliseconds
  volatile uint8_t counter = 0;
  SIGNAL(TIMER0_COMPA_vect) {
    // this gets called every 2 milliseconds
    counter += 2;
    // every 20 milliseconds, refresh the servos!
    if (counter >= 20) {
      counter = 0;
      tinyServo.refresh();
Thanks
