I m a Student of engineering and I want to make "Home Automation Through Web " As My FYP. In this regard i want to know that can I make a complete HTML Web page through which i can control almost 15 appliances.
some Posts says that through Arduino programming we can not make large web pages.
Also i have seen some examples in which it is controlling upto 2 appliances
With a 328, you can probably do enough html code to control all of it, just not very pretty though.
HTML requires a lot of space... especially on an Arduino where it's very limited.
On my Mega though, it's no problem. 10-15 devices is not an issue, especially if they're just Digital I/O.
However, I wrote an Android App instead, so that all the UI are handled by the Android device instead so proccessing is lower on the Arduino side. But it's definitely possible just to run everything on the arduino if it's a Mega... the 328 might be pushing it. The 168 is definitely a no go since it barely handled 4 devices code before it start crashing and doing all sorts of weird stuff.
it really depends what you define as a large webpage. You will be limited to html and java (no css etc) and the memory of the arduino is a possible contraint.
If you simply want 15+ tick boxes which can be toggled to turn lights on/off then that's easy and you will have no problem at all. Or if you want to control analoge devices (i.e. Temperature) then you can use a text field and a submit button.
As zoomkat mentioned, you will need to multiplex some of the outputs to get to 15 (or use a mega), but again that isn't too difficult.
actually my target is to make the page with 20 on-off buttons,4-analogue status and some text and i also want a good looking web page so now I want to know that can I make it using Arduino UNO. Also I want to include GSM module code as a backup controller for appliances
If your a smart HTML wizard, you can make a fancy website (even with multiple pages) with lots of inputs like text fields, radio buttons or checkboxes. And you can reuse HTML parts. I'll post a link to my own CastDuino project to show you what you can make.
You can make a client side html with lots of js, css and images and call the web services server (arduino + ethernet) with JSONP. The server side code could be the same for 3 ot 15 devices since you can encode the the device no in the web service call. I did that and it works on most browsers and devices.
Good luck
adis:
Good luck
Hi Adis.
Would you share your code for using the JSONP method? please
I have been thinking along the same lines; serving a fancy webpage from an actual server, and just fetching some simple values from the arduino, to include on the fancy webpage.
