Hey,
I have a code which is working in MSP430 with DS3231 on a PCB, Now i have changed the design instead of DS3231 i have used pcf8563 and running the same code but it's not working. so i want to replace Ds3231 code with pcf8563.
Can anyone help me.
main code-
#include "Wire.h"
#include "RTClib.h"
RTC_DS3231 rtc;
int count =0;
int z=0;
int m=0;
#define EEPROM_I2C_ADDRESS 0x80
int address[]={
0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16}; //17 Bytes
byte dataw[]={
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
byte datar[]={
/////////////////////////////////////////////////////////////////thermistor
int ThermistorPin = 2;
int Vo;
float R1 = 4700;
float logR2, R2, T, Tc, Tf;
float c4 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
int time1=0;
int time2=0;
int time3=0;
int time4=0;
int time5=0;
int timenow=0;
int ack=0;
int test=0;
int k=24;
int a1,b1,c1,d1,e1=0;
int a,b,c=0;
delay(100);
Wire.setModule(0);
pinMode(19,OUTPUT); //PWM Pin
pinMode(6,OUTPUT); //Bulkhead LED Indicator
pinMode(2,INPUT); //Temperature Input
if (! rtc.begin()){
Serial.println("Couldn't find RTC");
while (1);
Wire.begin();
if(count%k==0)
Serial.print("brk");
Serial.print("{"LampA":{");
Serial.print(""Temperature":");
Serial.print(Tc-20);
Serial.print(","Count":");
Serial.print(count);
Serial.print(","Loop":");
Serial.print(test);
Serial.print(","timenow":");
Serial.print(timenow);
Serial.print(","Ack":");
Serial.print(ack);
Serial.println("}}");
ack=0;
Vo = analogRead(ThermistorPin);
R2 = R1 * (1023.0 / (float)Vo - 1.0);
logR2 = logf(R2);
T = (1.0 / (c4 + c2logR2 + c3logR2logR2logR2));
Tc = T - 273.15;
Tf = (Tc * 9.0)/ 5.0 + 32.0;
DateTime now = rtc.now();
/Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
delay(10);/
if (Serial.available() > 0) {
for(int n=0; n<17; n++){
dataw[n] = Serial.read();
delay(10);
////////////////////////////////////////////////////////////////////////RF DEBUG
if(dataw[0]==72)
count=0;
dataw[0]=73;
//////////////////////////////////////////////////////////////////////////count value
if(dataw[0]==74)
k=dataw[1];
dataw[0]=75;
count++;
///////////////////////////////////////////////////////////////////////////////set time
if(dataw[0]==76)
rtc.adjust(DateTime(2017, 1, 21, dataw[1], dataw[2], 0));
dataw[0]=77;
/////////////////////////////////////////////////////////////////////////////bulkhead
if(dataw[0]==78)
m=dataw[1];
digitalWrite(7,m);
//////////////////////////////////////////////////////////////////////////////eeprom write
// Serial.print(","Writing:"");
if(dataw[0]==70)
// Serial.print("1");
for(int x=0;x<17;x++)
writeAddress(address[x], dataw[x]);
ack=1;
dataw[0]=71;
a1,b1,c1,d1,e1=0;//////////////////////////////////////////////////////////////////////////RESET LEVELS
//Serial.print("0");
datar[x] = readAddress(address[x]);
timenow =((now.hour()*60)+now.minute());
time1 = ((datar[1]*60)+datar[2]);
time2 = ((datar[3]*60)+datar[4]);
time3 = ((datar[5]*60)+datar[6]);
time4 = ((datar[7]*60)+datar[8]);
time5 = ((datar[9]60)+datar[10]);
Serial.print(","time1:"");
Serial.print(time1);
Serial.print(","time2:"");
Serial.print(time2);
Serial.print(","time3:"");
Serial.print(time3);
Serial.print(","time4:"");
Serial.print(time4);
Serial.print(","time5:"");
Serial.print(time5);
Serial.print(","timenow:"");
Serial.println("}");
if(time1>time2)
a1=0;
else{
a1=1;
if(time2>time3)
b1=0;
else{
b1=1;
if(time3>time4)
c1=0;
else{
c1=1;
if(time4>time5)
d1=0;
else{
d1=1;
if(time1>time5)
e1=0;
else{
e1=1;
if((time1==0) && (time2==0) && (time3==0)&&(time4==0)&&(time5==0))
analogWrite(19,255);
test=1;
else if((time1==time2) && (time1==time2) && (time1==time3)&& (time1==time4)&&(time1==time5))
analogWrite(19,datar[11]);
test=2;
if((timenow>=time1) && (a1==1) && (timenow<time2))
test=3;
else if((a1==0) &&(timenow<time2) && (timenow<720) && (timenow<time1))//////////////////////////////repeat same for other loops also 20.07.2017
test=4;
else if((a1==0) &&(timenow>time2) && (timenow>720)&&(timenow>=time1))
test=5;
if((timenow>=time2) && (b1==1) && (timenow<time3))
analogWrite(19,datar[12]);
test=6;
else if((b1==0) &&(timenow<time3) && (timenow<720) && (timenow<time2))
test=7;
else if((b1==0) &&(timenow>time3) && (timenow>720) && (timenow>=time2))
test=8;
if((timenow>=time3) && (c1==1) && (timenow<time4))
analogWrite(19,datar[13]);
test=9;
else if((c1==0) &&(timenow<time4) && (timenow<720) && (timenow<time3))
test=10;
else if((c1==0) &&(timenow>time4) && (timenow>720) && (timenow>=time3))
test=11;
if((timenow>=time4) && (d1==1) && (timenow<time5))
analogWrite(19,datar[14]);
test=12;
else if((d1==0) &&(timenow<time5) && (timenow<720) && (timenow<time4))
test=13;
else if((d1==0) &&(timenow>time5) && (timenow>720) && (timenow>=time4))
test=14;
//////////////////////////////////////////////////////////////////////////////////////OFF
if((timenow>=time5) && (timenow>time1) && (e1==1)&&(time1!=time5))
test=15;
else if((timenow<time5) && (timenow<time1) && (e1==1)&&(time1!=time5))
test=16;
else if((e1==0) &&(timenow<time1) && (timenow<720) && (timenow>=time5))
test=17;
else if((e1==0) &&(timenow<time1) && (timenow>720) && (timenow>=time5))
test=18;
delay(50);
////////////////////////////////////End of Void Loop
////////////////////////////////////Library Definition
void writeAddress(int address, byte val)
Wire.beginTransmission(EEPROM_I2C_ADDRESS);
Wire.write((int)(address >> 8)); // MSB
Wire.write((int)(address & 0xFF)); // LSB
Wire.write(val);
Wire.endTransmission();
delay(5);
byte readAddress(int address)
byte rData = 0xFF;
Wire.requestFrom(EEPROM_I2C_ADDRESS, 1);
rData = Wire.read();
return rData;
//////////////////////////////////////////////////End of Library Definition
Thanks
