I'm going to build my own Arduino on a breadboard using just an ATMega168 along with a MiniUSB-adapter. I made a simple DASA programmer and managed to get the avr-gcc program blink_1MHz on http://www.sparkfun.com/commerce/present.php?p=BEE-2-Code working. I then read this guide: Arduino Playground - Burn168 on how to burn the bootloader but when I was going to burn the fuse bits with avrdude on a command line in Ubuntu I must have messed something up because now I can't access the ATmega anymore. The command line I used was:
$ avrdude -c dasa -p m168 -P /dev/ttyS0 -U lfuse:w:0xf8:m -U hfuse:0xdf:m
And when I now try to reprogram it I just get the following message from avrdude:
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
I looked in the Atmega168 datasheet and figured out that it might be running on a 32768Hz clock crystal. So I hooked one up to the osc. pins 9 and 10 and tried again but no result.
Before I blew it the fuses was:
lfuse = 0x62
hfuse = 0xdf
efuse = 0x1
