Need help sending HTTP GET command (please)
Hello All:
I have an Arduino Uno with a SeeedStudio Ethernet Shield v2.0
It's set up as a test while I learn....just lighting LEDs and Relays for now.
Currently it is setup like a WebServer where I can call HTTP Requests from the web (or an iOS app called AEC - Arduino Ethernet Controller...but that app is just making the requests when you press a button).
Everything above is working fine.
I recently took apart a wireless doorbell and attached it to the Arduino. I have the RF board powered by the breadboard and wired to one pin on the Arduino from it's speaker wire. When the doorbell goes off, the arduino detects the HIGH reading on the pin.
I want the arduino to then send an HTTP GET request to a webaddress/service that sends a notification to my pebble watch. (Called Doorbell on the Pebble store).
I dont know how to make this request withing the sketch. I tried a few examples after searching but could never make it happen.
Could someone please take a look. I don't know how to do this...and I really have tried.
My current functions are doorBell() and dbNotify() starting on line 94.
void doorBell()
  int dbPressed = digitalRead(19);
  if (dbPressed == HIGH) {
  digitalWrite(ledRed, HIGH);
  digitalWrite(ledGreen, HIGH);
  digitalWrite(ledAmber, HIGH);
  digitalWrite(ledRed, LOW);
  digitalWrite(ledGreen, LOW);
  digitalWrite(ledAmber, LOW);
  dbNotify();
  delay(3000); //prevent multiple function calls because it's connected to speaker wire.
void dbNotify() //client function to send/receive GET request data.
 if (client.connect(dbServer, 80)) {
    Serial.println("Doorbell Server Connected");
    Serial.println("==========================");
    client.println("GET /doorbell/?key=1234567890 HTTP/1.0"); // Make a HTTP request:
    client.println();
  else {
    // if you didn't get a connection to the server:
    Serial.println("Doorbell Connection Failed");
Full code is attached.....
AEC-Test.txt (9.8 KB)
The code you posted does something. It is not at all clear what it does.
          linebuffer[20];
This is beyond the end of the array. Not that it actually DOES anything.
Between the (mis)use of the String class, and all the string literals that are copied unnecessarily into SRAM, you are probably running out of memory.
Save a lot of it by using the F() macro.
Serial.println(F("DHCP configuration failed. Trying again..."));
Save even more by ditching the String class.
Basic event based client code you might modify to test your bell setup. Note that you will probably need something like a 2000ms delay after your button event so only one notification will be sent instead of a bunch.
//zoomkat 3-1-13
//simple client checkip test
//for use with IDE 1.0.1 or later
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("Better client ip test 3/1/13"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET / HTTP/1.1"); //download text
    client.println("Host: checkip.dyndns.com");
    client.println("Connection: close");  //close 1.1 persistent connection
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
Thanks for the replies...I'll continue to test and re-write. I'll report back. The watch notification service may be broken as I'm getting delayed responses when sending via browser (my visitor will leave before I know the bell rang). But I'm still determined to get the code working. Thanks.
