Hi all was wondering if you could help me with these errors?
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino: In function 'void setup()':
Garden_2:86:3: error: 'dht' was not declared in this scope
86 | dht.begin();
Garden_2:90:3: error: 'rtc' was not declared in this scope
90 | rtc.begin();
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino: In function 'void loop()':
Garden_2:114:23: error: 'dht' was not declared in this scope
114 | float temperature = dht.readTemperature();
Garden_2:201:21: error: 'moistureLow' was not declared in this scope
201 | if (rain == 1 || !moistureLow) {
Garden_2:208:23: error: 'dht' was not declared in this scope
208 | float temperature = dht.readTemperature();
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino: In lambda function:
Garden_2:214:47: error: 'temperature' is not captured
214 | String message = "Temperature: " + String(temperature) + " C\n" +
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:212:19: note: the lambda has no capture-default
212 | server.on("/", []() {
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:208:9: note: 'float temperature' declared here
Garden_2:215:44: error: 'humidity' is not captured
215 | "Humidity: " + String(humidity) + " %";
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:209:9: note: 'float humidity' declared here
209 | float humidity = dht.readHumidity();
Garden_2:243:7: error: 'rain' was not declared in this scope
243 | if (rain == 1 || !moistureLow) {
Garden_2:243:21: error: 'moistureLow' was not declared in this scope
Garden_2:251:23: error: 'dht' was not declared in this scope
251 | float temperature = dht.readTemperature();
Garden_2:256:18: error: 'rtc' was not declared in this scope
256 | DateTime now = rtc.now();
Garden_2:257:49: error: invalid operands of types 'const char*' and 'const char [2]' to binary 'operator+'
257 | String time = now.hour() + ":" + now.minute() + ":" + now.second();
| const char* const char [2]
Garden_2:263:47: error: 'temperature' was not declared in this scope
263 | String message = "Temperature: " + String(temperature) + " C\n" +
Garden_2:264:44: error: 'humidity' was not declared in this scope
264 | "Humidity: " + String(humidity) + " %\n" +
Garden_2:299:23: error: 'dht' was not declared in this scope
299 | float temperature = dht.readTemperature();
Garden_2:303:18: error: 'rtc' was not declared in this scope
303 | DateTime now = rtc.now();
Garden_2:304:49: error: invalid operands of types 'const char*' and 'const char [2]' to binary 'operator+'
304 | String time = now.hour() + ":" + now.minute() + ":" + now.second();
Garden_2:309:47: error: 'temperature' is not captured
309 | String message = "Temperature: " + String(temperature) + " C\n" +
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:307:19: note: the lambda has no capture-default
307 | server.on("/", []() {
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:299:9: note: 'float temperature' declared here
Garden_2:310:44: error: 'humidity' is not captured
310 | "Humidity: " + String(humidity) + " %\n" +
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:300:9: note: 'float humidity' declared here
300 | float humidity = dht.readHumidity();
Garden_2:311:33: error: 'time' is not captured
311 | "Time: " + time;
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:304:10: note: 'String time' declared here
Garden_2:330:45: error: 'temperature' is not captured
330 | String message = "Temperature: " + String(temperature) + " C\n" +
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:328:21: note: the lambda has no capture-default
328 | server.on("/data", []() {
Garden_2:331:42: error: 'humidity' is not captured
331 | "Humidity: " + String(humidity) + " %\n" +
Garden_2:332:31: error: 'time' is not captured
332 | "Time: " + time;
Garden_2:334:67: error: 'moistureLevels' is not captured
334 | message += "\nMoisture sensor " + String(i+1) + ": " + String(moistureLevels[i]);
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:274:7: note: 'int moistureLevels [4]' declared here
274 | int moistureLevels[numSensors];
Garden_2:372:21: error: 'moistureLow' was not declared in this scope
372 | if (rain == 1 || !moistureLow) {
Garden_2:379:23: error: 'dht' was not declared in this scope
379 | float temperature = dht.readTemperature();
Garden_2:383:18: error: 'rtc' was not declared in this scope
383 | DateTime now = rtc.now();
Garden_2:384:49: error: invalid operands of types 'const char*' and 'const char [2]' to binary 'operator+'
384 | String time = now.hour() + ":" + now.minute() + ":" + now.second();
Garden_2:389:47: error: 'temperature' is not captured
389 | String message = "Temperature: " + String(temperature) + " C\n" +
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:387:19: note: the lambda has no capture-default
387 | server.on("/", []() {
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:379:9: note: 'float temperature' declared here
Garden_2:390:44: error: 'humidity' is not captured
390 | "Humidity: " + String(humidity) + " %\n" +
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:380:9: note: 'float humidity' declared here
380 | float humidity = dht.readHumidity();
Garden_2:391:33: error: 'time' is not captured
391 | "Time: " + time;
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:384:10: note: 'String time' declared here
Garden_2:409:47: error: 'temperature' is not captured
409 | String message = "Temperature: " + String(temperature) + " C\n" +
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:407:23: note: the lambda has no capture-default
407 | server.on("/data", []() {
Garden_2:410:44: error: 'humidity' is not captured
410 | "Humidity: " + String(humidity) + " %\n" +
Garden_2:411:33: error: 'time' is not captured
411 | "Time: " + time;
Garden_2:413:69: error: 'moistureLevels' was not declared in this scope
413 | message += "\nMoisture sensor " + String(i+1) + ": " + String(moistureLevels[i]);
Garden_2:417:1: error: expected '}' at end of input
417 | }
/Volumes/Ardunio_Projects/Garden_2/Garden_2.ino:101:13: note: to match this '{'
101 | void loop() {
Multiple libraries were found for "RTClib.h"
Used: /Users/darksplat/Documents/Arduino/libraries/RTClib
Not used: /Users/darksplat/Documents/Arduino/libraries/RTCLib_by_NeiroN
exit status 1
* Here is a sketch outline for an ESP8622 with 4 moisture sensors, 1 DHT sensor, 1 rain sensor,
* 1 RTC module (DS3231), and a relay that can turn on and off a water valve:
* Initialize the ESP8622 and set up the WiFi connection.
* Initialize the DHT sensor and RTC module.
* Initialize the 4 moisture sensors and the rain sensor.
* Set up a server on the ESP8622 to allow access to the device through a web interface.
* In the main loop of the sketch, continually read the values from the moisture sensors, DHT sensor, and rain sensor.
* If the moisture level of any of the sensors falls below a certain threshold, turn on the relay to open the water valve.
* If the rain sensor detects rain, turn off the relay to close the water valve.
* Use the DHT sensor to read the temperature and humidity and display these values on the web interface.
* Use the RTC module to display the current time on the web interface.
* Use the web interface to manually turn the relay on or off and to access the data from the sensors and RTC
* Use the web interface to access data from www.bom.gov.au to retrieve the current weather conditions in the local area and display this information on the web interface.
* This code sets up the server to handle incoming client requests by defining three different server routes: /, /on, and /off.
* The / route is accessed when the client sends a request to the root URL of the server. When this happens, the server will send back a message containing the current temperature, humidity, and time values.
* The /on and /off routes are accessed when the client sends a request to the /on or `/
#define A0 0
#define A1 14
#define A2 15
#define A3 16
#define DHTPIN 2 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22 // DHT 22 (AM2302)
// Initialize the ESP8622 and set up the WiFi connection:
#include <ESP8266WiFi.h>
// Initialize the DHT sensor and RTC module:
#include <DHT.h>
#include <Wire.h>
#include <RTClib.h>
// Set up a server on the ESP8622 to allow access to the device through a web interface:
#include <ESP8266WebServer.h>
const char* ssid = "YOUR_SSID";
const char* password = "YOUR_PASSWORD";
// Create an instance of the server
// specify the port to listen on as an argument
ESP8266WebServer server(80);
// Initialize the 4 moisture sensors and the rain sensor:
const int numSensors = 4; // Number of moisture sensors
const int sensors[] = {A0, A1, A2, A3}; // Analog pins connected to the sensors
const int rainPin = 4; // Digital pin connected to the rain sensor
WiFi.begin(ssid, password);
// Wait for the WiFi connection to be established
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
// Set up the server
server.begin();
Serial.println("Server started");
// Set up the DHT sensor
DHT dht(DHTPIN, DHTTYPE);
// Set up the RTC module
RTC_DS3231 rtc;
dht.begin();
// Initialize the RTC module
rtc.begin();
// Initialize the moisture sensors and rain sensor
for (int i = 0; i < numSensors; i++) {
pinMode(sensors[i], INPUT);
pinMode(rainPin, INPUT);
// Check for incoming client requests
server.handleClient();
// In the main loop of the sketch, continually read the values from the moisture sensors, DHT sensor, and rain sensor:
// Read the values from the moisture sensors
moistureLevels[i] = analogRead(sensors[i]);
// Read the temperature and humidity from the DHT sensor
// Read the value from the rain sensor
int rain = digitalRead(rainPin);
// If the moisture level of any of the sensors falls below a certain threshold, turn on the relay to open the water valve:
const int moistureThreshold = 700; // Adjust this value based on the range of your sensors
const int relayPin = 5; // Digital pin connected to the relay
// Check if the moisture level of any of the sensors is below the threshold
bool moistureLow = false;
if (moistureLevels[i] < moistureThreshold) {
moistureLow = true;
// If the moisture is low, turn on the relay to open the water valve
if (moistureLow) {
digitalWrite(relayPin, HIGH);
digitalWrite(relayPin, LOW);
// If the rain sensor detects rain, turn off the relay to close the water valve:
moistureLow = true;
// If it is raining or the moisture is not low, turn off the relay to close the water valve
// Use the DHT sensor to read the temperature and humidity and display these values on the web interface:
moistureLow = true;
{ // Read the temperature and humidity from the DHT sensor
// Set up the server to handle incoming client requests
// Send the temperature and humidity values to the client
server.send(200, "text/plain", message);
// Use the RTC module to display the current time on the web interface:
moistureLow = true;
// Read the current time from the RTC module
// Send the temperature, humidity, and time values to the client
"Time: " + time;
// Use the web interface to manually turn the relay on or off and to access the data from the sensors and RTC:
moistureLow = true;
"Time: " + time;
server.on("/on", []() {
// Turn on the relay
server.send(200, "text/plain", "Relay turned on");
server.on("/off", []() {
// Turn off the relay
server.send(200, "text/plain", "Relay turned off");
"Time: " + time;
// Use the web interface to access data from www.bom.gov.au to retrieve the current weather conditions in the local area and display this information on the web interface.
server.begin();
// Set up the connection to www.bom.gov.au
const char* serverName = "www.bom.gov.au";
WiFiClient client;
moistureLow = true;
"Time: " + time;
"Time: " + time;
Cheers
