Need help Something with [] buffer
Hi
Is’t from an Anduino+python script
I got a problem when I try to catch the input from “messageFromPC” buffer.
char messageFromPC[buffSize] = {0};
Here is it been set…
char * strtokIndx; // this is used by strtok() as an index
  strtokIndx = strtok(inputBuffer,",");      // get the first part - the string
  strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
Here will I try to catch it:
if (String(messageFromPC == "97")) {
      dosomething();
    } else if (String(messageFromPC == "98")) {
      dosomeOtherthing();
Here comes the return from Arduino
Sent from PC – LOOP NUM 0 TEST STR <98,0,0>
Reply Received Msg 98 Time 1
The reply seems to be a string Msg 98
and this looks like a string TEST STR <98,0,0>
How can I get the messageFromPC correct!
Are the brackets in the right place ?
So Robin tries to keep you away from the String (capital S) class :slight_smile: and the first thing you do is re-introduce it :frowning:
Read up on c-strings, the function you're looking for is strcmp()
Thanks
For you quick reply...
