Need Help Start Button Help to lance Programme
the probleme i can’t configure my Start Button to lance my program …
I put all my call function to setup to make them just one time because in loop function they be repeted
So I need help to make the fuction called just one time in Loop and make my start Button work when he is pushed … This is my program:
#include <QTRSensors.h>
#define NUM_SENSORS 6 // number of sensors used
#define NUM_SAMPLES_PER_SENSOR 4 // average 4 analog samples per sensor reading
#define EMITTER_PIN 2 // emitter is controlled by digital pin 2
#define sagmotor1 9
#define sagmotor2 10
#define solmotor1 3
#define solmotor2 11
#define MZ80 5
#define startbuton 2
QTRSensorsAnalog qtra((unsigned char) {0, 1, 2, 3, 4, 5},
NUM_SENSORS, NUM_SAMPLES_PER_SENSOR, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
unsigned long Last_Time = 0;
unsigned long Start = 0;
const int LED = 26;
int leftmotor, rightmotor, Integral = 0;
int error, last_error;
int Power_Motor;
int Position = 0;
int last_value = 0;
int Background = 1;
int i = 0;
pinMode(sagmotor1, OUTPUT);
pinMode(sagmotor2, OUTPUT);
pinMode(solmotor1, OUTPUT);
pinMode(solmotor2, OUTPUT);
pinMode(MZ80, INPUT_PULLUP);
pinMode(startbuton, INPUT_PULLUP);
for (int i = 0; i < 150; i++)
if ( 0 <= i && i < 5 ) Motor(35,-35);
if ( 5 <= i && i < 15 ) Motor(-35,35);
if ( 15 <= i && i < 25 ) Motor(35,-35);
if ( 25 <= i && i < 35 ) Motor(-35,35);
if ( 35 <= i && i < 40 ) Motor(35,-35);
if ( 45 <= i && i < 55 ) Motor(-35,35);
if ( 55 <= i && i < 65 ) Motor(35,-35);
if ( 65 <= i && i < 75 ) Motor(-35,35);
if ( 75 <= i && i < 80 ) Motor(35,-35);
if ( i >= 80 ) {
Motor(0,0);
delay(3);
qtra.calibrate();
delay(1);
if (digitalRead(startbuton)==HIGH) { do frenle(); while(digitalRead(startbuton)==HIGH);} // He doesn’t work :frowning:
if (digitalRead(startbuton)==LOW) { Motor(0,0);}
TrackTime(60,0.05,0,0.8,1000);
TrackTime(40,0.05,0,0.8,1000);
Motor(0, 0);
Please post your code using code tags so it makes it easier for people to help you.
I think you want your code to wait for the start button to be pressed before it does anything.
A couple of things to note
  • your do…while() loop inside setup needs braces.
  • if your start button is INPUT_PULLUP, it reads LOW when it is pressed, not HIGH
try this untested code
#define sagmotor1 9
#define solmotor1 3
#define MZ80 5
QTRSensorsAnalog qtra((unsigned char[]) {
  0, 1, 2, 3, 4, 5
const int LED = 26;
int Power_Motor;
int Position = 0;
int last_value = 0;
int Background = 1;
int i = 0;
int lastButtonState;
    if ( 0 <= i && i < 5   ) Motor(35, -35);
    if ( 5 <= i && i  < 15   ) Motor(-35, 35);
    if ( 15 <= i && i < 25   ) Motor(35, -35);
    if ( 25 <= i && i < 35   )  Motor(-35, 35);
    if ( 35 <= i && i < 40   )  Motor(35, -35);
    if ( 45 <= i && i < 55   )  Motor(-35, 35);
    if ( 55 <= i && i < 65   )  Motor(35, -35);
    if ( 65 <= i && i < 75   ) Motor(-35, 35);
    if ( 75 <= i && i < 80   )  Motor(35, -35);
    if ( i >= 80  )  {
      Motor(0, 0);
      delay(3);
    qtra.calibrate();
    delay(1);
    if (digitalRead(startbuton) == HIGH) {
      do {
        frenle();   // He doesn't work :(
      } while (digitalRead(startbuton) == HIGH);
  lastButtonState = digitalRead(startbutton);
  int state = digitalRead(startbutton);
  if ( lastButtonState != state ) {
    // button changed state
    lastButtonState = state;
    if ( state == LOW ) {
      // button was pushed
      doButtonPushed();
      // button was released
      doButtonReleased();
void doButtonPushed() {
    TrackTime(60, 0.05, 0, 0.8, 1000);
    TrackTime(40, 0.05, 0, 0.8, 1000);
void doButtonReleased() {
  Motor(0,0);
You SHOULD put do...while loop outside of the for loop. Currently you are putting while loop inside of the for loop.
Also, I recommend to print some log to Serial Monitor for debugging purpose.
I am begginer in arduino programme but i thank that there is a confusion between Emitter_pin he work with pin number 2 and the Startbuton he use pin number 2
what you think he doesn’t work the push buton
#define sagmotor1 9
#define solmotor1 3
#define MZ80 5
int state = digitalRead(startbuton);
      doButtonPushed();
      doButtonReleased();
  Motor(0,0);
I eliminate EMITTER_PIN now the start Buton work but i must push the Buton twice (2 times ) why ?!!
Help me to make it work just onetime just i push it one time work…
#define sagmotor1 9
#define solmotor1 3
#define MZ80 5
QTRSensorsAnalog qtra((unsigned char[]) {0, 1, 2, 3, 4, 5},
  NUM_SENSORS, NUM_SAMPLES_PER_SENSOR);
  1. You should NOT share a pin between EMITTER_PIN and startbuton pin.
  2. You should debounce for the button. See Button debounce tutorial
  3. I recommend to unify the coding style (variable naming style)
