need help streaming data with UNO and SEEED GSM/GPRS V2.0
configuration:
-iOS mavericks
-arduino uno
-SEEED GSM/GPRS V2.0
-unlocked and verified AT&T SIM card with data only (No SMS or Voice Calls)
How do I stream voltage readings from an analog sensor onto the web?
I'm using m2x.att.com as my API, but I'm open and interested in other options--perhaps something with a better support community.
This is the code I'm using:
#include "SerialModem.h"
#include "jsonlite.h"
#include "M2XStreamClient.h"
SerialModemClient client;
char m2xFeedId[] = "df60542f9f2ee9c1fed588320363b823";    // Feed you want to post to
char m2xKey[] = "30700b29c45af8922ec95e659e5da7a0";    // Your M2X access key
M2XStreamClient m2xClient(&client, m2xKey);
const int SENSOR = 0; // selects the input pin for the thermistor
int val = 0; //variable used to store the value coming from the sensor
  // Note: Analogue pins are always and
  // automatically set as inputs
  Serial.begin(115200); // in tutorial it was 9600
  while (!Serial);
  SerialModem.setDriver(DRIVER_MTSMC_H5);
  SerialModem.setSerial(&Serial, 115200);
  while (!SerialModem.ready()) {
    Serial.println("waiting for modem ready..");
    delay(100);
  while (SerialModem.getNetworkStatus() < NETWORK_STATUS_ROAMING) {
    Serial.println("waiting for network registration");
    delay(2000);
  while (!SerialModem.setAPN("wap.cingular")) {
    Serial.println("setting APN");
    delay(2000);
  val = analogRead(SENSOR); //read the value from the sensor
  Serial.println(val); // print the value to the serial port
  delay(1000); // wait 100 ms between each send
I also tried using the following code to test my modem:
 This example test if your modem is working correctly.
 Circuit:
 * GSM shield attached (using digital pins 2, 3, and 7)
 Created 12 Jun 2012
 by David del Peral
 modified 21 Nov 2012
 by Tom Igoe
// libraries
#include <GSM.h>
// modem verification object
GSMModem modem;
// IMEI variable
String IMEI = "";
  // initialize serial communications
  // start modem test (reset and check response)
  Serial.print("Starting modem test...");
  if(modem.begin())
    Serial.println("modem.begin() succeeded");
    Serial.println("ERROR, no modem answer.");
  // get modem IMEI
  Serial.print("Checking IMEI...");
  IMEI = modem.getIMEI();
  // check IMEI response
  if(IMEI != NULL)
    // show IMEI in serial monitor
    Serial.println("Modem's IMEI: " + IMEI);
    // reset modem to check booting:
    Serial.print("Reseting modem...");
    modem.begin();
    // get and check IMEI one more time
    if(modem.getIMEI() != NULL)
      Serial.println("Modem is functoning properly");
      Serial.println("Error: getIMEI() failed after modem.begin()");
    Serial.println("Error: Could not get IMEI");
  // do nothing:
  while(true);
and I got "Error: Could not get IMEI"
I also gave up on m2x. I've tried xively as well, but that is not going well either. I've got the same setup as you. What I do know though, is that the .setDriver method in your M2x code refers to a model of gprs shield that is different from yours.
