Need help to burn an EPROM
Anyone know how i can burn an EPROM (27c64) using arduino?
Back in the 1980s there were DIY projects for making EPROM programmers that ran off the PC parallel port. You should be able to do something similar with 74HC595s.
http://eshop.engineering.uiowa.edu/NI/pdfs/01/03/DS010331.pdf
It’s possible to do the programming with simple tools but you can get a cheap programmer for 39.00. I’ve not used it but will be looking at getting one for my own use.
EPROMs...EPROMs...yes I remember them.
Do you have an eraser? We used to use a small UV light.
Rob
