The code i am using is as follows
#include <IRremote.h>
Left Motor
// IN 1
#define LM_IN1 2
// IN 2
#define LM_IN2 4
Right Motor
// IN 3
#define RM_IN3 5
// IN 4
#define RM_IN4 7
// IR receiver
# define RECV_PIN 10
IRrecv irrecv(RECV_PIN);
decode_results results;
//HEX codes for buttons
#define FWD 0xFD8877 // go forward
#define LFT 0xFD28D7 // go left
#define RGT 0xFD6897 // go right
#define BWD 0xFD9867 // go backward
#define STOP 0xFD30CF // stop
#define RPEAT 0xFD708F // repeat the stored sequence of movement from the temporary memory(automatically stores)
#define DEL 0xFDB04F // delete the stored sequence of movement from temporary memory(EQ)
#define RESET 0xFD00FF // Resets the Arduino Board(RED)
unsigned long int value = 0; // stores the incoming hex value
byte seq = 0; //stores the current number of executed sequences
byte seq_Array[50];// array to store the movement sequence in terms of integers(1 for FWD, 2 for LEFT and so on..)
//counter for counting the number of times program pass through a movement function(fwd, lft etc.)
int fwd_Counter = -1;
int lft_Counter = -1;
int rgt_Counter = -1;
int bwd_Counter = -1;
int stp_Counter = -1;
//global "current time" variables for different movement functions(fwd, lft etc.)
unsigned long int current_Time0 = 0;// for FWD movement
unsigned long int current_Time1 = 0;// for LEFT movement
unsigned long int current_Time2 = 0;// for RIGHT movement
unsigned long int current_Time3 = 0;// for BWD movement
unsigned long int current_Time4 = 0;// for STOP
//total time spend by the pgm in executing the movement(fwd, lft etc.) for a particular movement counter
unsigned long int total_Fwd_Time[10];
unsigned long int total_Lft_Time[10];
unsigned long int total_Rgt_Time[10];
unsigned long int total_Bwd_Time[10];
unsigned long int total_Stp_Time[10];
************Arduino Reset Pin**************
#define RESET_PIN A0
// set mode of the pins as output
for (int i = 2; i <= 7; i++) {
pinMode(i, OUTPUT);
// start serial communication
// In case the interrupt driver crashes on setup, give a clue
// to the user what's going on.
Serial.println("Enabling IRin");
irrecv.enableIRIn(); // Start the receiver
Serial.println("Enabled IRin");
if (irrecv.decode(&results)) {
value = results.value;
Serial.println(value, HEX);
irrecv.resume(); // Receive the next value
delay(200);
delay(100);
check_Inst(value);
value=0;
void check_Inst(long int value) {
switch (value) {
case FWD:
go_Forward();
delay(10);
case LFT:
go_Left();
delay(10);
case RGT:
go_Right();
delay(10);
case BWD:
go_Backward();
delay(10);
case STOP:
go_Stop();
delay(10);
case RPEAT:
go_In_Seq();
delay(10);
case DEL:
del_From_Local_Mem();
delay(10);
case RESET:
pinMode(RESET_PIN,OUTPUT);
digitalWrite(RESET_PIN,HIGH);
default:
value = 0;
void go_Forward() {
movement_Inst_Fwd();
current_Time0 = millis();
int i = seq_Array[(seq - 1)];
switch (i) {
case 2:
total_Lft_Time[lft_Counter + 1] = (current_Time0 - current_Time1);
lft_Counter++;
case 3:
total_Rgt_Time[rgt_Counter + 1] = (current_Time0 - current_Time2);
rgt_Counter++;
case 4:
total_Bwd_Time[bwd_Counter + 1] = (current_Time0 - current_Time3);
bwd_Counter++;
case 5:
total_Stp_Time[stp_Counter + 1] = (current_Time0 - current_Time4);
stp_Counter++;
seq_Array[seq] = 1;
seq++;
void go_Left() {
movement_Inst_Lft();
current_Time1 = millis();
switch (i) {
case 1:
total_Fwd_Time[fwd_Counter + 1] = (current_Time1 - current_Time0);
fwd_Counter++;
case 3:
total_Rgt_Time[rgt_Counter + 1] = (current_Time1 - current_Time2);
rgt_Counter++;
case 4:
total_Bwd_Time[bwd_Counter + 1] = (current_Time1 - current_Time3);
bwd_Counter++;
case 5:
total_Stp_Time[stp_Counter + 1] = (current_Time1 - current_Time4);
stp_Counter++;
seq_Array[seq] = 2;
seq++;
void go_Right() {
movement_Inst_Rgt();
current_Time2 = millis();
switch (i) {
case 1:
total_Fwd_Time[fwd_Counter + 1] = (current_Time2 - current_Time0);
fwd_Counter++;
case 2:
total_Lft_Time[lft_Counter + 1] = (current_Time2 - current_Time1);
lft_Counter++;
case 4:
total_Bwd_Time[bwd_Counter + 1] = (current_Time2 - current_Time3);
bwd_Counter++;
case 5:
total_Stp_Time[stp_Counter + 1] = (current_Time2 - current_Time4);
stp_Counter++;
seq_Array[seq] = 3;
seq++;
void go_Backward() {
movement_Inst_Bwd();
current_Time3 = millis();
switch (i) {
case 1:
total_Fwd_Time[fwd_Counter + 1] = (current_Time3 - current_Time0);
fwd_Counter++;
case 2:
total_Lft_Time[lft_Counter + 1] = (current_Time3 - current_Time1);
lft_Counter++;
case 3:
total_Rgt_Time[rgt_Counter + 1] = (current_Time3 - current_Time2);
rgt_Counter++;
case 5:
total_Stp_Time[stp_Counter + 1] = (current_Time3 - current_Time4);
stp_Counter++;
seq_Array[seq] = 4;
seq++;
void go_Stop() {
movement_Inst_Stp();
current_Time4 = millis();
switch (i) {
case 1:
total_Fwd_Time[fwd_Counter + 1] = (current_Time4 - current_Time0);
fwd_Counter++;
case 2:
total_Lft_Time[lft_Counter + 1] = (current_Time4 - current_Time1);
lft_Counter++;
case 3:
total_Rgt_Time[rgt_Counter + 1] = (current_Time4 - current_Time2);
rgt_Counter++;
case 4:
total_Bwd_Time[bwd_Counter + 1] = (current_Time4 - current_Time3);
bwd_Counter++;
seq_Array[seq] = 5;
seq++;
void go_In_Seq(void) {
value = 0;
for (int i = 0; i < (seq + 1); i++) {
int value1 = 0;
value1 = seq_Array[i];
switch (value1) {
case 1:
static int j = 0;
go_Forward_Seq(j);
j++;
case 2:
static int k = 0;
go_Left_Seq(k);
k++;
case 3:
static int l = 0;
go_Right_Seq(l);
l++;
case 4:
static int m = 0;
go_Backward_Seq(m);
m++;
case 5:
static int n = 0;
go_Stop_Seq(n);
n++;
default:
j = 0; k = 0; l = 0; m = 0; n = 0;
void del_From_Local_Mem() {
//set the movement counters to their default values
fwd_Counter = -1;
lft_Counter = -1;
rgt_Counter = -1;
bwd_Counter = - 1;
stp_Counter = - 1;
//set the total movement time to its default value
for (int i = 0; i < 10; i++) {
total_Fwd_Time[i] = 0;
total_Lft_Time[i] = 0;
total_Rgt_Time[i] = 0;
total_Bwd_Time[i] = 0;
total_Stp_Time[i] = 0;
// Reset the sequence array(stored movement instructions)
for (int i = 0; i < 50; i++) {
seq_Array[i] = 0;
seq = 0;
value = 0;
These function moves the car in a direction for the time specified/stored in the total_x_time array
void go_Forward_Seq(int j) {
//go in forward direction sequence
movement_Inst_Fwd();//
delay(total_Fwd_Time[j]);
void go_Left_Seq(int k) {
//go in Left direction sequence
delay(total_Lft_Time[k]);
void go_Right_Seq(int l) {
//go in right direction sequence
delay(total_Rgt_Time[l]);
void go_Backward_Seq(int m) {
//go in backward direction sequence
delay(total_Bwd_Time[m]);
void go_Stop_Seq(int n) {
//go in Stop sequence
delay(total_Stp_Time[n]);
These movement instruction are repeated(required) several times in the code
void movement_Inst_Fwd(void) {
Serial.println("Going_Forward");
// forward movement instructions
digitalWrite(LM_IN1, HIGH);
digitalWrite(LM_IN2, LOW);
digitalWrite(RM_IN3, HIGH);
digitalWrite(RM_IN4, LOW);
void movement_Inst_Lft(void) {
Serial.println("Going_Left");
// Left movement instructions
digitalWrite(LM_IN1, LOW);
digitalWrite(RM_IN3, LOW);
void movement_Inst_Rgt(void) {
Serial.println("Going_Right");
// Rgt movement instructions
void movement_Inst_Bwd(void) {
Serial.println("Going_Backward");
// Bwd movement instructions
digitalWrite(LM_IN2, HIGH);
digitalWrite(RM_IN4, HIGH);
void movement_Inst_Stp(void) {
Serial.println("Stopping");
// Stp movement instructions
at the moment I am using a it receiver and it remote to control the car but now I wanna use my phone to control it....is there any way I could do that?
