Need help to create client. Using arduino Ethernetshield and UDP
Hello. I have some code here, that store the Digitalread value of a switch I have hooked up. I need some help with the client. Any suggestion on how I can get the value from the server and to the Client? I have tried to make a python script, and I think It work, but I cannot acutally see if the Switch has been pressed or not. When you want to send the information digitalRead capture, what Is it? A string? Look at my code, and maybe you get what I want. This is the server side:
#include <Ethernet.h> //Load Ethernet Library
#include <EthernetUdp.h> //Load the Udp Library
#include <SPI.h> //Load SPI Library
#include "Wire.h" //imports the wire library
int Switch;
byte mac[] ={ 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEE}; //Assign mac address
IPAddress ip(10, 0, 0, 13); //Assign the IP Adress
unsigned int localPort = 100; // Assign a port to talk over
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //dimensian a char array to hold our data packet
String datReq; //String for our data
int packetSize; //Size of the packet
EthernetUDP Udp; // Create a UDP Object
  Serial.begin(9600); //Initialize Serial Port
  Ethernet.begin( mac, ip); //Inialize the Ethernet
  Udp.begin(localPort); //Initialize Udp
  delay(1500); //delay
  pinMode(3, INPUT);
  packetSize =Udp.parsePacket(); //Reads the packet size
  if(packetSize>0) { //if packetSize is >0, that means someone has sent a request
    Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE); //Read the data request
    String datReq(packetBuffer); //Convert char array packetBuffer into a string called datReq
    if (datReq =="Switch") { //Do the following if Switch is requested
      Switch = digitalRead(3); //Read the switch statement
      if(digitalRead(3)){
      Serial.println("ON");
        Serial.println("OFF");
      Udp.beginPacket(Udp.remoteIP(), Udp.remotePort()); //Initialize packet send
      Udp.print(Switch); //Send the Switch data
      Udp.endPacket(); //End the packet
  memset(packetBuffer, 0, UDP_TX_PACKET_MAX_SIZE); //clear out the packetBuffer array
The Switch variable is an integer converted to a string. That is what you are sending. The packet should contain the integer value converted to a string. It should be a '1' or '0'.
edit: I have UDP "client" C code for a Linux (Ubuntu) box.
So on the server side, what should I change? Can you show with some code, then I understand it better? :slight_smile: Thanks!
No change on the Arduino side if a text 1 or 0 is what you want to send.
Yes, I want to send 1 when the switch is pressed and 0 when the button is not pressed. But I need some help in the client, to ask for the switch statement. Is the switch a 0 or 1? And then print this information in the client. I need some code help with that If you have some extra time? If you can help me out, I can pay you 50 $ If I get this to work? :slight_smile:
I have a little extra time. What language and operating system are you using?
