The code from:
https://create.arduino.cc/projecthub/lightthedreams/how-to-connect-remote-control-4-channel-to-arduino-dc8e33?ref=platform&ref_id=424_popular___&offset=4959
In my understood, because of the D0/D1 are momentary 'HIGH' when be trigger, the LED ought to ON just a moment then off, in fact it keep on till next trigger. why?
Thanks
Adam
/* https://create.arduino.cc/projecthub/lightthedreams/how-to-connect-remote-control-4-channel-to-arduino-dc8e33?ref=platform&ref_id=424_popular___&offset=4959
// constants won't change. They're used here to
// set pin numbers:
const int button1 = 10; // WAS:1-4the number of the pushbutton pin
const int button2 = 11;
const int ledPin1 = 12; // the number of the LED pin
const int ledPin2 = 13;
// Variables will change:
int ledState1 = HIGH; // the current state of the output pin
int ledState2 = HIGH;
int buttonState1; // the current reading from the input pin
int buttonState2;
int lastButtonState1 = LOW; // the previous reading from the input pin
int lastButtonState2 = LOW;
// the following variables are unsigned long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 50; // the debounce time; increase if the output flickers
pinMode(button1, INPUT);
pinMode(button2, INPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
// set initial LED state
digitalWrite(ledPin1, ledState1);
digitalWrite(ledPin2, ledState2);
// read the state of the switch into a local variable:
int reading1 = digitalRead(button1);
int reading2 = digitalRead(button2);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading1 != lastButtonState1) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading1 != buttonState1) {
buttonState1 = reading1;
// only toggle the LED if the new button state is HIGH
if (buttonState1 == HIGH) {
ledState1 = !ledState1;
// set the LED:
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
lastButtonState1 = reading1;
if (reading2 != lastButtonState2) {
if (reading2 != buttonState2) {
buttonState2 = reading2;
if (buttonState2 == HIGH) {
ledState2 = !ledState2;
// set the LED:
lastButtonState2 = reading2;
