Hello,
For a project i'm working on i need to insert a pressure sensor inside a squeeze ball. The sensor should send the pressure to a PC. I already got this working with a pressure sensor inside the ball, connected to the Arduino which is connected to the PC.
I would like to make this ball controller wireless using Bluetooth / WiFi. Is there any Arduino board / other board i can use which is small enough to work with batteries and inserted into an a squeeze ball that can fit in a hand?
Thank you !
