Need help to incorporate this timer to an existing code
Hello, everyone!
I need help here. I am looking to incorporate a timer function to an existing code that sends out an audio signal continuously. In the existing code when the push button is pressed the signal is sent out continuously along with a blinking led. To this, I would like the timer function to be incorporated which will make the same pushbutton send the signal out for a period of 10 seconds only.
I am giving the existing code as below. Would someone be able to help me with this project, please!
Thanks in advance.
Karan
Existing Code:
#include <TimerOne.h>
#include <avr/io.h>
#include <avr/interrupt.h>
uint16_t syncPhaseAcc;
uint16_t syncPhaseInc;
uint16_t grainPhaseAcc;
uint16_t grainPhaseInc;
uint16_t grainAmp;
uint8_t grainDecay;
uint16_t grain2PhaseAcc;
uint16_t grain2PhaseInc;
uint16_t grain2Amp;
uint8_t grain2Decay;
// Map Analogue channels
#define SYNC_CONTROL (4)
#define GRAIN_FREQ_CONTROL (0)
#define GRAIN_DECAY_CONTROL (2)
#define GRAIN2_FREQ_CONTROL (3)
#define GRAIN2_DECAY_CONTROL (1)
// Changing these will also requires rewriting audioOn()
#if defined(AVR_ATmega8)
// On old ATmega8 boards.
// Output is on pin 11
#define PWM_PIN 11
#define PWM_VALUE OCR2
#define PWM_INTERRUPT TIMER2_OVF_vect
#elif defined(AVR_ATmega1280)
// On the Arduino Mega
// Output is on pin 3
#define PWM_PIN 3
#define PWM_VALUE OCR3C
#define PWM_INTERRUPT TIMER3_OVF_vect
#else
// For modern ATmega168 and ATmega328 boards
#define PWM_PIN 3
#define PWM_VALUE OCR2B
#endif
// Smooth logarithmic mapping
uint16_t antilogTable[] = {
64830, 64132, 63441, 62757, 62081, 61413, 60751, 60097, 59449, 58809, 58176, 57549, 56929, 56316, 55709, 55109,
54515, 53928, 53347, 52773, 52204, 51642, 51085, 50535, 49991, 49452, 48920, 48393, 47871, 47356, 46846, 46341,
45842, 45348, 44859, 44376, 43898, 43425, 42958, 42495, 42037, 41584, 41136, 40693, 40255, 39821, 39392, 38968,
38548, 38133, 37722, 37316, 36914, 36516, 36123, 35734, 35349, 34968, 34591, 34219, 33850, 33486, 33125, 32768
uint16_t mapPhaseInc(uint16_t input) {
return (antilogTable[input & 0x3f]) >> (input >> 6);
// Stepped chromatic mapping
uint16_t midiTable[] = {
17, 18, 19, 20, 22, 23, 24, 26, 27, 29, 31, 32, 34, 36, 38, 41, 43, 46, 48, 51, 54, 58, 61, 65, 69, 73,
77, 82, 86, 92, 97, 103, 109, 115, 122, 129, 137, 145, 154, 163, 173, 183, 194, 206, 218, 231,
244, 259, 274, 291, 308, 326, 346, 366, 388, 411, 435, 461, 489, 518, 549, 581, 616, 652, 691,
732, 776, 822, 871, 923, 978, 1036, 1097, 1163, 1232, 1305, 1383, 1465, 1552, 1644, 1742,
1845, 1955, 2071, 2195, 2325, 2463, 2610, 2765, 2930, 3104, 3288, 3484, 3691, 3910, 4143,
4389, 4650, 4927, 5220, 5530, 5859, 6207, 6577, 6968, 7382, 7821, 8286, 8779, 9301, 9854,
10440, 11060, 11718, 12415, 13153, 13935, 14764, 15642, 16572, 17557, 18601, 19708, 20879,
22121, 23436, 24830, 26306
uint16_t mapMidi(uint16_t input) {
return (midiTable[(1023 - input) >> 3]);
// Stepped Pentatonic mapping
uint16_t pentatonicTable[54] = {
0, 19, 22, 26, 29, 32, 38, 43, 51, 58, 65, 77, 86, 103, 115, 129, 154, 173, 206, 231, 259, 308, 346,
411, 461, 518, 616, 691, 822, 923, 1036, 1232, 1383, 1644, 1845, 2071, 2463, 2765, 3288,
3691, 4143, 4927, 5530, 6577, 7382, 8286, 9854, 11060, 13153, 14764, 16572, 19708, 22121, 26306
uint16_t mapPentatonic(uint16_t input) {
uint8_t value = (1023 - input) / (1024 / 53);
return (pentatonicTable[value]);
void audioOn() {
// ATmega8 has different registers
TCCR2 = _BV(WGM20) | _BV(COM21) | _BV(CS20);
TIMSK = _BV(TOIE2);
TCCR3A = _BV(COM3C1) | _BV(WGM30);
TCCR3B = _BV(CS30);
TIMSK3 = _BV(TOIE3);
#else
// Set up PWM to 31.25kHz, phase accurate
TCCR2A = _BV(COM2B1) | _BV(WGM20);
TCCR2B = _BV(CS20);
TIMSK2 = _BV(TOIE2);
#endif
#define NUM_POT (3)
#define NUM_LED (NUM_POT + 1)
int potVal[NUM_POT];
byte ledDuty[NUM_LED];
byte ledState[NUM_LED];
byte ledCount[NUM_LED];
byte ledPin[NUM_LED] = { 4, 5, 6, 2};
unsigned long savedTime, newTime;
volatile byte makeSound = 1;
//init global variable
for (byte i = 0; i < NUM_LED; i++) {
ledCount = 0;
_ ledState = HIGH;_
_ pinMode(ledPin*, OUTPUT);
}_
pinMode(ledPin[NUM_LED - 1], OUTPUT);
ledDuty[NUM_LED - 1] = 80; //alive led*
* savedTime = 0;*
* //start audino library*
* pinMode(PWM_PIN, OUTPUT);
_ audioOn();
//read all pot val*
* for (byte i = 0; i < NUM_POT; i++) {*
potVal = analogRead(i);
ledDuty = (byte) (potVal / 4);
if (ledDuty < 16) {
ledDuty = 0;
else if (ledDuty > 240) {
ledDuty = 255;
//code belong to audino project*
* // syncPhaseInc = mapPentatonic(analogRead(SYNC_CONTROL));
// grainPhaseInc = mapPhaseInc(analogRead(GRAIN_FREQ_CONTROL)) / 2;
// grainDecay = analogRead(GRAIN_DECAY_CONTROL) / 8;
// grain2PhaseInc = mapPhaseInc(analogRead(GRAIN2_FREQ_CONTROL)) / 2;
// grain2Decay = analogRead(GRAIN2_DECAY_CONTROL) / 4;*
* // YOU CAN CHANGE BELOW equations*
* syncPhaseInc = mapPentatonic(potVal[0]);
grainPhaseInc = mapPhaseInc(potVal[1]) / 2;
grainDecay = potVal[2] / 16;
grain2PhaseInc = mapPhaseInc( (potVal[0] + potVal[1]) / 2 ) / 2;
grain2Decay = (potVal[1] + potVal[2]) / 8;
newTime = millis();
if (newTime - savedTime > 4) {
savedTime = newTime;_
LED_ControlBlink();
_ }
//===========================================_
void LED_ControlBlink() {
_ switch (ledDuty) {
case 0: ledState = HIGH; break; //always on
case 255: ledState = LOW; break; //always off
default: //else*
ledCount*++;_
if (ledCount _== ledDuty) {_
ledState _= ! ledState;
ledCount = 0;
} //end switch*
* if (analogRead(NUM_POT) < 400) {
ledState[NUM_LED - 1] = HIGH;*
* makeSound = 0;
else {
makeSound = 1;
digitalWrite(ledPin, ledState); //output led state*
* } //end for*
SIGNAL(PWM_INTERRUPT)
* uint8_t value;
uint16_t output;*
* if (! makeSound) {_
PWM_VALUE = 0;
_ return;
syncPhaseAcc += syncPhaseInc;
if (syncPhaseAcc < syncPhaseInc) {
// Time to start the next grain*
* grainPhaseAcc = 0;
grainAmp = 0x7fff;
grain2PhaseAcc = 0;
grain2Amp = 0x7fff;
// Increment the phase of the grain oscillators*
* grainPhaseAcc += grainPhaseInc;
grain2PhaseAcc += grain2PhaseInc;
// Convert phase into a triangle wave*
* value = (grainPhaseAcc >> 7) & 0xff;
if (grainPhaseAcc & 0x8000) value = ~value;
// Multiply by current grain amplitude to get sample*
output = value * (grainAmp >> 8);
* // Repeat for second grain*
* value = (grain2PhaseAcc >> 7) & 0xff;
if (grain2PhaseAcc & 0x8000) value = ~value;
output += value * (grain2Amp >> 8);
// Make the grain amplitudes decay by a factor every sample (exponential decay)
grainAmp -= (grainAmp >> 8) * grainDecay;
grain2Amp -= (grain2Amp >> 8) * grain2Decay;
// Scale output to the available range, clipping if necessary*
* output >>= 9;
if (output > 255) output = 255;
// Output to PWM (this is faster than using analogWrite)_
PWM_VALUE = output;
_}*_
Do you see the smilies and italics in your code ?
Please read the stickies at the top of the forum about how to post a programming question
